shaved door
Old Mar 17, 2002 | 10:22 PM
integra95's Avatar
Default shaved door
how much does shaved door cost. I getting my car repainted so I was thinking about getting it done. How much is it with the shaved door, kit, remote to open door.
Old Mar 18, 2002 | 07:33 AM
Thrashin's Avatar
Default Re: shaved door (integra95)
yeah that **** would be hot b, my boyee has his doors shaved like the dukes of hazard car and its hot as hell yo! do it holmes
Old Mar 18, 2002 | 07:35 AM
BakedCookies's Avatar
Default Re: shaved door (jdmeg6)
yeah i like to run real fast and slide through my window, me and cousin cooter do it all the time... we slide up in daisy too..
Old Mar 18, 2002 | 07:48 AM
X2BOARD's Avatar
Shaddap guys.... I have shaved doors...
heheh... it costs about $450+ for a good job for just the body work
The solenoids, wiring, relays... blah,blah,blah about $300-$400 for parts, you must have a complatible alarm
If you don't do it yourself (hardware), (I did, it's a bitch!)... It's about a $250 install from a shop..
So about $700-$1100 for it to be done right.. and you MUST get it done by a shop that has experience in it...
Old Mar 18, 2002 | 09:24 AM
jamal-188's Avatar
Default Re: shaved door (X2BOARD)
I think I paid $350 for body work/paint. The guy did an outstanding job!! He cut around my handle and welded a steel plate on, no crappy bondo job and will pop out in a year. The lines on the car match up 100%. I bought a solenoid kit for something like $150 at autoloc.com.
Old Mar 19, 2002 | 08:08 PM
integra95's Avatar
what did you use. The 50lbs or what
Old Mar 20, 2002 | 04:45 AM
jamal-188's Avatar
NO, mine were way smaller, either 11lbs or 15lbs. Just make sure if you're gonna install the kit yourself have a way to get in your car if the door doens't open right!! I don't know how many times I had to crawl thorugh my hatch of my VW until I got it working properly. I really had to rig the latch mechanism becasue the solenoid actually didn't pull far enough to fully open the lock.
Old Mar 20, 2002 | 06:04 AM
X2BOARD's Avatar
Default Re: shaved door (jamal-188)
Could have something to do with the solenoid's rating... I would not use anything less than a 35lbs solenoid for a front door and keep the 10-12lbs for your hood or trunk... the doors are too important to cheap out on... I went with 50 lbs on my front doors and 35's on my rears....
No probs with the solenoids after about 6 months in the heat and rain of Miami. Autoloc;.com's solenoids have a limited lifetime warranty too...
Old Mar 20, 2002 | 06:20 AM
jamal-188's Avatar
No, the solenoids pull hard enough, they just only pull like 1/2, so I just had to rig the latching mechanism by wrapping some heavy wire around it so it stays almost open all the time. Works great going on almost 3 years now! Just had to mess with it a little, but it was worth it, saved a few bucks!! The 35 or 50lb would have been too big to fit behind my door panels anyway.
Old Mar 20, 2002 | 06:23 AM
X2BOARD's Avatar
3 years ? Not too shabby ! Any problems with rust or anything on the solenoids so far ? Do you lube them at all ? I try keeping them coated in grease....
Old Mar 20, 2002 | 06:42 AM
jamal-188's Avatar
No, the solenoids haven't rusted to bad. I don't lube them at all, are you supposed to? I don't think the ones I have require lubricant?
Old Mar 20, 2002 | 07:23 AM
X2BOARD's Avatar
No, they are supposed to be relatively maintenance free, but I try to keep them coated lightly with some Lithium grease just to be safe...
I spent over $350 in parts for my setup (4 doors isn't cheap), so I want it to last a very long time.
Old Mar 20, 2002 | 07:31 AM
jamal-188's Avatar
yeah, lucky for me and my wallet my car is only a 2 door
Old Mar 20, 2002 | 07:53 PM
integra95's Avatar
Jamal 188 and x2board do you guys have msn messenger. Could i have you add me or let me add you to my list. I have a lot of question about this door shaving this. Thanx my address is dennis_rr4life@hotmail.com
Old Mar 22, 2002 | 05:11 AM
X2BOARD's Avatar
I don't have msn.... don't like getting IM's popping up constantly while at work... but email me if anything. I'll gladly answer any of your questions.
Old Mar 22, 2002 | 08:59 AM
SCsol's Avatar
shaved door suck a$$, i dont know how many times i close my friends door after drivin has car and lock the keys in without thinking then reaching for a handle that ant there DONT GET THEM if not done perfect they look like ****!!!! if your doing boby mods remove the side molding like the ITR's it will look much cleaner what ever you do good luck
Old Mar 22, 2002 | 09:22 AM
X2BOARD's Avatar
Default Re: shaved door (lowsol)
Of course they will look like **** if you get a body shop full of *** clowns...
I love the look of my car w/o handles... looks slick.. most people do triple takes. Plus it's ***** hard to steal my car... not only do you have to unlock it, then you have to figure out how to open the door... all while the alarm is going off !
Shaved door handles rule ! Ricers suck...
sackdz
Apr 3, 2006 08:58 AM
VietFoo
Apr 5, 2004 12:25 PM
civicsport
Jun 30, 2002 07:01 PM
Crossett
Nov 30, 2001 05:15 AM
Keane Rated R
Aug 22, 2001 03:51 PM
