09/01 S2000 swollowed valve!
Old Dec 23, 2005 | 05:57 PM
michaelk's Avatar
Default 09/01 S2000 swollowed valve!
02/ S2000 under warr. and not coverd! One valve broke off at stem and was told a over rev happened,I am a high performance diesel truck tech and will say I dont have a lot of exp. in imports but I am no fool and anyone with any exp. can see if a eng. is over reved more then one valve will be stuck!I pulled the PC mem of last 30 sec of life and the highest RPM was 7200 and red line is 9000,I also took a test drive in one from the dealer and asked what the rev limit was and this is what I was told( put it in sec gear and plant it to the floor the rev limiter wont allow it to over rev!)?????????????? please help me with this issuie
Old Dec 23, 2005 | 07:10 PM
Used2beAb16's Avatar
Default Re: 09/01 S2000 swollowed valve! (michaelk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by michaelk &raquo;</TD></TR><TR><TD CLASS="quote">02/ S2000 under warr. and not coverd! One valve broke off at stem and was told a over rev happened,I am a high performance diesel truck tech and will say I dont have a lot of exp. in imports but I am no fool and anyone with any exp. can see if a eng. is over reved more then one valve will be stuck!I pulled the PC mem of last 30 sec of life and the highest RPM was 7200 and red line is 9000,I also took a test drive in one from the dealer and asked what the rev limit was and this is what I was told( put it in sec gear and plant it to the floor the rev limiter wont allow it to over rev!)?????????????? please help me with this issuie </TD></TR></TABLE>
Try diff dealerships untill you find one thats covered.
Is this your motor? car?
They can check the mem as well and if you say it wasnt over 7,200 you make them show you when and where it shows that it went over factory redline.
Old Dec 23, 2005 | 08:17 PM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by michaelk &raquo;</TD></TR><TR><TD CLASS="quote">( put it in sec gear and plant it to the floor the rev limiter wont allow it to over rev!)?????????????? please help me with this issue </TD></TR></TABLE>
Just to address the potential to over rev: you can mechanically over rev an engine by shifting from 3rd gear at redline to, let's say, second gear.
Old Dec 23, 2005 | 11:50 PM
Default Re: 09/01 S2000 swollowed valve! (b19coupe)
if he downshifted they will know. Shouldn't have been the case if max rpm was 7,200.
Did you ever hit 2nd instead of 4th in it? 6 speed its been known to happen.
92 civic VX B18c
Honda S2000
67
Nov 9, 2006 08:25 AM
FF-Greg
Honda S2000
32
Dec 27, 2005 09:44 AM
michaelk
Honda S2000
Dec 13, 2005 09:21 PM
nqmt
Honda S2000
Jun 7, 2004 11:20 PM
