Suspension Settings for EF
Alright so I am going to be acquiring (sp?) a 91 DX. I will be putting on some omni coilovers. The car will be setup for drag and road racing. Now I understand the settings for drag. What is the best setup for road racing? Full stiff?
It depends on how you drive mostly.
I prefer semi-hard springs, stock front sway bar, and heavy rear sway bar. Typical range for springs is ~350-650 for the front and ~300-500 (rear should be between 75% front rate to 100% front rate IMO). I wouldn't go over 400 for such a light car unless it's just a track car.
That sort of setup tends to leave the rear 'loose', which facilitates rotation. Heavy sway bars keeps the car tight when you make quick steering inputs.
redzcstandardhatch
Feb 27, 2009 01:41 PM
Todd00
21
Apr 30, 2003 05:51 PM
