Help Cable to Hydro Conversion
I have a 90 ef b16a swapped civic I am looking to go hydro with a gsr Tranny, what all do I need to convert it, an what do I need to do as well
umm yea... your sort of forgetting the whole hydrolic clutch pedal assembly. in fact i very much want to switch to gsr tranny for my b16 crx. ive been told its quite expensive. but if you figure it out, ide like to know too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infested »</TD></TR><TR><TD CLASS="quote">umm yea... your sort of forgetting the whole hydrolic clutch pedal assembly. in fact i very much want to switch to gsr tranny for my b16 crx. ive been told its quite expensive. but if you figure it out, ide like to know too</TD></TR></TABLE>
hasport sells a hydro conversion kit, it uses the stock cable with a bracket to activate the clutch, no need for hydro pedal assembly
Considering I already havea hydro tranny, i'm pretty sure I know what I'm talking about.
Just buy the hapsort kit.
The problem with a Hasport kit - you're still using the cable. All you really get is more options for trannies (newer ones).
There's been a few people that have swapped their cable chassis to a full hydro clutch/clutch master&slavecyl/hydro lines/hydro pedal. Welding is neccessary, as is the use of a prelude master cyl or cutting your firewall to fit a civic/teg MC.
It would actually cost less to do that conversion than for a hasport kit, but of course - its not a bolt-on. I'm definately doing this if I can ever fine a clean, rust-free LX/EX shell.
Cable>hydro
But good luck with your conversion to hydro for under $400 b/c you can get the kit for that cheap. PLUS, you HAVE to buy mounts anyway since you are throwing in a B series. It's not cheaper in the long run for a COMPLETE hydro set-up.
viking-101
Jun 26, 2011 07:11 AM
dunkd
May 8, 2007 06:19 AM
swoosh
Mar 15, 2004 01:14 PM
crx1856
10
Nov 11, 2003 02:59 PM
