Installing a b16a/ITR LSD into a b16a transmission
hey guys, I've searched but couldn't find some the information I am looking for.
I am going to be purchasing a 2000 sir transmission without LSD.
Now I have worked on manual transmissions before but non were Honda's.
My first question is:
-If I buy a b16/itr LSD, will it bolt onto the final drive and into the transmission without problems even tho the transmission never came with LSD?
-To install the LSD it needs to be bolted onto the final drive, so am I able to slide the final drive assembly out without pulling out the main and counter shafts?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superdupervtec »</TD></TR><TR><TD CLASS="quote">You need a 4.4 ring gear from a gsr/type r
You need updated ball bearings for a gsr/type r
and it's a perfect fit.</TD></TR></TABLE>
ok yea I just found out I need the final drive from the ITR so I'll pass on that.
Lets say if I get a b16 LSD, it should just bolt in without any problems right? will I still need the LSD Final drive also?
99 TYPE R
Mar 10, 2004 08:22 PM
