HX wheels on Civic w/ gsr brakes *NEED HELP*
any know of what size spacers i need to clear the calipers......or anyone got pics of how much i need to shave off the caliper to get them to fit....?? i did a search found nothing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CLMTFabEG6 »</TD></TR><TR><TD CLASS="quote">or anyone got pics of how much i need to shave off the caliper to get them to fit </TD></TR></TABLE>
I would strongly recommend against shaving stuff off your caliper. The metal is there for a reason. The last thing you want is your brakes failing on you. Just my 2 cents
Cheers
Cheers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri »</TD></TR><TR><TD CLASS="quote">
Cheers</TD></TR></TABLE>
Thanks.......can i get away with a 3mm spacer??
I had to buy a set from the local auto parts store this week because my hx wheels wouldn't clear my ex front brake calipers. They're the UNIVERSAL Mr. Gasket - Wheel Spacer, 1/4'' Thick (about 6mm), Fits 4-''4.25'', 4-Lug Bolt Pattern...they did the trick for me. Plenty of clearance and no need for extended studs. $23.00 at O'Reily Auto Parts.
Here they are at JEGS: http://www.jegs.com/webapp/wcs...18581
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highroller54 »</TD></TR><TR><TD CLASS="quote">mine fit?? new pads and rotors (full width) close but no clearence issues.
What car? Front brakes? Wierd.
</TD></TR></TABLE>What car? Front brakes? Wierd.
<FONT COLOR="blue"> I've been doing some reading about HX on gsr brakes. I have a EG sedan with GSR brakes on all 4. I had some Q:
[color=orange]
What are the pros and cons of using spacers concerning the OFFSET?
What is the MIN mm I could use? cause 6mm seems overkill. </FONT>
[color=orange]
cherroneballs
10
May 1, 2008 04:15 PM
