tranny help wont go in
Old Dec 23, 2005 | 04:30 AM
si0385.'s Avatar
Default tranny help wont go in
i think i found the problem... when im trying to wiggle the tranny in the input shaft is spinning with the clutch and flywheel... anybody know how to lock upthe ring grear so i can put this thing inalready???
Modified by jaydeum4lyfe at 6:03 AM 12/23/2005
Old Dec 23, 2005 | 05:09 AM
WWDTrackRacer's Avatar
New User
Default doubtful the mainshaft is spinning
it takes a bit of effort for it to move. The clutch disc itself moves easier
but it shouldn't be loose behind the pressure plate.
Putting the tranny back on takes a bit of practice -- especially if you
don't have a crane/lift to hold the weight of it up as you line it up.
I used a crane to hold mine up. Eyeball it to make sure it's on the
same horizontal plane with the engine. push it in very slowly to the
clutch disc. it should still look centered. if it doesn't go right in, then
you rotate the tranny slightly (right and left) trying to get the splines
to line up. or back it out, and spin the mainshaft a little by hand.
Good luck. I've spent a few hours trying to line up a tranny without
the crane. It's a complete bitch.
Old Dec 23, 2005 | 06:16 AM
si0385.'s Avatar
i dont have a crane all i have is a jack and im usint that to hold up the motor... ive been fighting with it for over 2 hours now... anybody got any tricks that would help me out i would greatly appreciate it... i just cant get it to line up
Old Dec 23, 2005 | 06:52 AM
si0385.'s Avatar
Default Re: doubtful the mainshaft is spinning (WWDTrackRacer)
going on 3 hours now bump for some help
Old Dec 23, 2005 | 07:24 AM
SSJSubgeta's Avatar
Default Re: doubtful the mainshaft is spinning (jaydeum4lyfe)
It might not be the best advice technichaly but it sure does help...
FRIENDS , call them tell them to give you a hand cause you doing it by yourself is going to be a big PITA.
I did this just by myself and its no one man job unless you have the equipment....
Old Dec 23, 2005 | 11:14 AM
si0385.'s Avatar
Default Re: doubtful the mainshaft is spinning (SSJSubgeta)
believe me if i knew anybody around here i would deff ask for another hand... but im new in my town and dont know anybody
Old Dec 23, 2005 | 11:32 AM
driveahonda's Avatar
are you saying you cant get the tranny onto the block?? have you check to make sure the clutch is lined up right??
Old Dec 23, 2005 | 05:13 PM
si0385.'s Avatar
Default Re: (driveahonda)
i found the problem the si tranny has 21 splines on the input shaft and the dx tranny has 20... the input shaft on the si tranny is also alittle bit bigger...
after fighting whith this thing for what seemed like forever i decided to pay attention to detail
OBDII Integra
Sep 11, 2009 08:56 PM
ftrms
Mar 5, 2009 06:23 AM
extensioncordy
Dec 25, 2006 03:13 PM
preludebabygrl
May 30, 2003 08:24 PM
