cant get tranny to line up
its a 96 civic dx putting a 99 civic hx tranny in. got it alll out put new clutch on and cannot get the tranny to line up. we can get bolts in but will not pull together.
one side seems to come together easier but the back side is like a inch apart
Re: cant get tranny to line up (extensioncordy)
do you have two people? air tools? i had to change a clutch a few weks ago. with two people to line the tranny up its not too hard but may take a little wiggling.
Re: cant get tranny to line up (MikeD718)
Two people help out alot. One below the tranny and one above. Might go in easy or it might take 5 mins. Try turning the input shaft little by little. Thats all I can say. Just keep trying it'll go on.
Re: cant get tranny to line up (haveaniceday)
I had the same problem once. Turned out they sent me the wrong clutch disk and it wouldn't mesh with the input shaft on the tranny. I had to pull the PP back off and try to try to slide the disk on the shaft before I was sure.
Put the tranny in gear, stick an axle in one side and have someone turn it while you try to mesh them together. Whatever you do, don't draw it up with bolts. You'll just F something up. It should slide together pretty easily or else something's wrong.
Are you 100% sure that you clutch disk is alined with the pilot bearing? I have seen people slightly knock it over somehow and make it impossible for the trans to go in.
Make sure the clutch disc is still aligned by using the clutch alignment tool-if it wasn't aligned right the 1st time or if it got moved by poking it w/the trannys input shaft when trying to line it up,it won't work-not doubting your abilities,just trying to give u the benefit of my experience(mistakes!)
yea i have done alot of clutches on honda's and even 2 on a vw. i just dont know. we had 3 ppl tryin to get this thing on last night. i have done it by myself before. it sucks. but i did. but we get the tranny to start going on. get a few bolts in. but it just wont go in, it gets to a point were it stops and the bolts feel like theyre bottemed out
vtecn8ive
23
04-23-2006 06:59 PM
