civic ex brake switch over
Old Dec 23, 2005 | 12:26 AM
boylovecar's Avatar
Default civic ex brake switch over
can someone hook me up with a parts list for this swap. also i read that the rotors won't work is this right? do i need aftermarket or maybe i read wrong. and will the rear brakes swap over as well, are they 10.3 inch too? bump the oem big brake swap. yeahyah. (insert techno music)
Old Dec 23, 2005 | 01:43 PM
boylovecar's Avatar
Default Re: civic ex brake switch over (boylovecar)
bump
Old Dec 23, 2005 | 04:31 PM
EL Vap133's Avatar
The 1990-1991 Civic EX did not have rear dis brakes in the US. The fronts will bolt right up and yes you can use the rotors.
Old Dec 23, 2005 | 05:17 PM
boylovecar's Avatar
Default Re: civic ex brake switch over (EL Vap133)
thank you sir, now what would work to match the front as a 10.3 brake upswap? would the 92-95 si or ex rear brakes work and will they be ok as to not upset the balance of the car. or what would be ok to pair w/ the 90-91 ex brakes for the rear.
Old Dec 23, 2005 | 05:27 PM
silentdork818's Avatar
90-93 Integra or 90-91 CRX Si rear discs. Im sure 92-00 Civic and 94+ Integra discs are the same too. I think theyre 9.2" in diameter. Just make sure you use a 40/40 proportioning valve from a 90-93 non-abs Integra.
Old Dec 23, 2005 | 05:54 PM
Default Re: civic ex brake switch over (silentdork818)
And the proper e-brake cables (DA cables for hatch/sedan, 90-91 CRX Si cables for CRX).
Old Dec 23, 2005 | 07:14 PM
boylovecar's Avatar
thank you for your response, i neglected to mention that my crx 90-91 si and has four disc brakes. i'm looking to upgrade to 10.3 to all four corners. i understand fastbrakes puts together a fantastic package, but i'm looking for other options. i know there is much debate on whether da brakes upset the cars balance thats why i'm leaning w/ the ex brakes and something to match in the rear.
Old Dec 23, 2005 | 07:16 PM
EL Vap133's Avatar
Leave the rears as they are, upgrade the fronts to the EX brakes. Get a 90-91 Integra NON-ABS MC/BB, steel braided lines, and some good pads and you'll certainly feel the difference.
Old Dec 23, 2005 | 11:07 PM
boylovecar's Avatar
thanks again, aiming to get earl's brake lines, mc/bb, ex civic front brakes w/rotors, and new pads. should keep the horses in check. my guesstimated price is 3-400 total. not bad for a huge improvement.
Old Dec 24, 2005 | 01:48 PM
EL Vap133's Avatar
Not at all, you're gonna love the difference!
citystreetsbimmer
Suspension & Brakes
Mar 10, 2008 07:02 AM
ef 4 door
Dec 14, 2006 11:02 AM
makaveli284
Jun 15, 2004 09:59 PM
HT Chaplain
14
Aug 14, 2003 08:20 PM
Jason84
Jul 3, 2003 12:45 AM
