93' Higher Mount Stop Light Problem
Old Dec 23, 2005 | 12:23 AM
Dongoesby's Avatar
Default 93' Higher Mount Stop Light Problem
It is the stop light where behind the rear window, it is in the model before year 93 only I guess. Well, it has two light bulbs in it, one went out, so I bought a new bulb, but it doesn't work. So then I swap them, it new one worked in the other spot, but the one working bulb didn't work after the swap. Then I took the whole assemply out, I found out a black wire had spliced and electric taped. Is this what caused the problem, or other reasons?
Old Dec 23, 2005 | 06:40 AM
The_Sober's Avatar
Default Re: 93' Higher Mount Stop Light Problem (Dongoesby)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dongoesby &raquo;</TD></TR><TR><TD CLASS="quote">I found out a black wire had spliced and electric taped. Is this what caused the problem?</TD></TR></TABLE>
yes. replace the wire and make a proper connection and you should be ok
Old Dec 23, 2005 | 07:02 AM
Nick99's Avatar
Default Re: 93' Higher Mount Stop Light Problem (The_Sober)
When you clean up the connection make sure to shrink wrap it and do it properly.
Maybe the last owner or a mechanic did a quick fix?
Old Dec 23, 2005 | 09:47 AM
Dongoesby's Avatar
Default Re: 93' Higher Mount Stop Light Problem (Nick99)
it is not factory came out like this, anyone think?
98dxkoupe
May 18, 2015 01:54 AM
BrayzieEF9
Jan 14, 2010 10:01 AM
crxrider
12
Sep 11, 2007 07:17 AM
vthree
May 6, 2006 03:56 PM
