Tach not working??
Old Mar 17, 2002 | 07:36 PM
Eg6_JDM's Avatar
Default Tach not working??
took car into the shop to get it rewired for b16a.......now tach isnt working........
i've heard this problem occur often, so does anyone have an ideal?????
thanks
[Modified by Eg6_JDM, 6:22 AM 3/18/2002]
Old Mar 18, 2002 | 07:53 AM
Eg6_JDM's Avatar
Default Re: Tach not working?? (Eg6_JDM)
i know theres got to be someone who fixed their tach b4.....or knows what to do
Old Mar 18, 2002 | 08:09 AM
EE_Chris's Avatar
Tach signal is typically taken from the igniter.
Perhaps somewhere along the way they didn't reconnect whatever connector they disconnected that carries this signal to your tach. ( - how do you like that wording)
Since it seems you don't have a factory manual for your ride, I'd suggest to start tracing where the wires go....assuming that its a connector that goes nowhere, you will have easily solved your problem.
Old Mar 18, 2002 | 08:28 AM
Eg6_JDM's Avatar
Default Re: Tach not working?? (EE_Chris)
thanks....but no wire is out or loose......
Old Mar 18, 2002 | 08:37 AM
Kamin's Avatar
No, there is a wire that is out or loose or the tach would be working hehe
check the harness on the drivers side of the engine bay near the firewall. i dont know the color code of the wires or i would give more detailed instructions on what to do. keep watching this thread i know someone around here knows the wiring colors.
Old Mar 18, 2002 | 08:43 AM
Eg6_JDM's Avatar
Default Re: Tach not working?? (KAMiN)
someone told me that i have to run a wire from the distributor to the back of the dash.......
both blue wires.......im not sure what he talking about cuz i dont see a blue wire from the distributor.......but is this correct?
Old Mar 18, 2002 | 09:51 AM
D16Z6racing's Avatar
if you have indiglos, that could be a problem too. sometimes the face will slide down over a period of time and rest on the needle, not allowing it to move. just another idea.
Old Mar 18, 2002 | 10:14 AM
hybridreams's Avatar
Default Re: Tach not working?? (buster13)
Whoever told you it needs to be wired directly to the distributor is correct. The shop could've tapped into a dead wire and not checked it. Sorry I don't know the wire coloring
Old Mar 18, 2002 | 10:33 AM
Eg6_JDM's Avatar
Default Re: Tach not working?? (hybridreams)
thanks everyone
CLE
12
Oct 31, 2007 07:31 PM
Mikey3000
Sep 6, 2006 02:32 PM
OneThirtyEight
Jan 10, 2005 06:05 AM
