Removing the crank pulley
Old Dec 22, 2005 | 04:58 PM
Perogi's Avatar
Default Removing the crank pulley
I'm trying to remove the crank pulley on my b16a right now and have run into a few problems. First of all when i try to remove the bolt that holds the pully in place i end up just cranking over the engine. The sparkplugs are installed and are about hand tight. I've tried holding the cam gear with a wrench while cranking on the pulley bolt. It's deffinetly snug on there so i was wondering if i should just give er' **** and crank on the damn bolt as hard as i can or will it demage the timing belt?
I also plan on removing the cam gears to change the cam seals after the new T-belt is in place, so same question, how i i keep them from turning over as i loosen the bolts?
Old Dec 22, 2005 | 05:19 PM
C1CRX's Avatar
Traffic signal tech
Default Re: Removing the crank pulley (Perogi)
go rent a pulley remover tool from your local autoparts store and do it the right way
Old Dec 22, 2005 | 05:29 PM
green91's Avatar
the removal tool + air impact gun
Old Dec 22, 2005 | 07:02 PM
T3k C's Avatar
I used a chain wrench, wrap it around the pulley. Get a long *** breaker bar and that did it for me.
Old Dec 22, 2005 | 07:26 PM
crx2nr822's Avatar
Default Re: (B16DSEF)
Get a bad *** impact gun.......should pop right off. I remember when I was trying to take off my crank pulley from my b16 when it was OUT of the car.....that thing was a bitch. We didnt have an impact strong enough to take it off, so we used like a 3 foot breaker bar to get that thing off.
socialistic
31
Jun 26, 2011 12:54 PM
Yolandita
May 21, 2006 06:54 PM
grngsr01
Oct 23, 2005 05:47 AM
TrueZen
Feb 27, 2004 07:42 AM
Milano97
Jun 2, 2002 04:59 PM
