92-93 to 94-96 el gauge cluster conversion
Old Dec 22, 2005 | 02:31 PM
Jos3ph's Avatar
Default 92-93 to 94-96 el gauge cluster conversion
my friend w/ a 95 prelude crashed his car and he's selling me his el gauge cluster w/ wiring and dimmer box for $50 and i was wondering if it's just plug and play. All the parts are still in his car so what exactly do i need to remove from his car in order for the el gauge cluster to work in my 93 lude? Also, where do i detach the wiring harness from his car? Thanks
Old Dec 22, 2005 | 04:34 PM
Elkins911's Avatar
Default Re: 92-93 to 94-96 el gauge cluster conversion (Jos3ph)
yes, its completely plug and play. i recently converted the guages, its worth the time and effort... its a little difficult to work the harness out of the car especially if his car has an alarm.
good luck, hit me up if you have any questions.
Old Dec 22, 2005 | 05:54 PM
Prelude SIR-T's Avatar
Default Re: 92-93 to 94-96 el gauge cluster conversion (Elkins911)
it ISNT plug and play UNLESS you take the whole dash harness. which i recommend you do or else you will be splicing wires and doing a lot of work that will take you hours, i have done it both ways and i recommend the dash harness after the extensive extra labor that wasnt necessary. if you decide to do the splicing way i recommend searching it because there are write ups on it. if you do get the harness and hook it all up you will have one plug on the right side that doesnt plug into anything you have to take that black wire and hook it to the ground or else your blinkers and things wont work other wise everything is good to go. hope this helps
Old Dec 22, 2005 | 07:00 PM
Jos3ph's Avatar
Default Re: 92-93 to 94-96 el gauge cluster conversion (jdmhore)
i forgot to mention that i have the 92-93 fog light switch installed in the tweeter so will that be problem since the fog light switch for the 94-96 lude is located on the e-brake console.
Old Dec 22, 2005 | 09:24 PM
support1's Avatar
Hi , tomorrow I bought a EL glow speedometer and i think that this cluster plug and play to my 93 prelude ...
Tell me, what is dimmer box ??? Dimmer box need to EL glow are working ???
To Jos3ph: Please post some photo of your EL Glow cluster ...
Modified by support1 at 11:13 PM 12/22/2005
Old Dec 22, 2005 | 10:16 PM
Jos3ph's Avatar
Default Re: 92-93 to 94-96 el gauge cluster conversion (support1)
i think it's called an inverter assembly, not dimmer box. It's what powers the el gauges. I'm buying the el gauge cluster from a friend but it's still in his car so i don't have any pictures of them. Does anyone know if the 92-93 fog light harness (attaches to the fog light switch located in the driver side tweeter) is seperate from the 94-96 dash harness that i need to install to get the el gauges working?
Old Dec 23, 2005 | 08:22 AM
support1's Avatar
Today i bought el light cluster too on eBay.com ... but seller have doesn't have an invertor...
If any body have invertor and can sell me it, write me ...
P.S. Sorry for my English ... ))
Old Dec 24, 2005 | 04:53 AM
support1's Avatar
Read this
http://www.vancouverpreludeclu...=6801
And post please some photos of invertor, please
Old Dec 24, 2005 | 05:03 PM
prelude72569858's Avatar
YOU WERE WAY BETTER OFF WAITING FOR ONE WITH IT, GOOD LUCK
Old Dec 24, 2005 | 08:26 PM
NeriVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by support1 &raquo;</TD></TR><TR><TD CLASS="quote">Read this
And post please some photos of invertor, please</TD></TR></TABLE>
You beat me to it,
Pics when you are finished
redberan1
Feb 25, 2014 04:59 PM
JDMb18c1HATCH
Mar 9, 2011 08:01 PM
DuVaL rAcEr
Dec 26, 2007 07:42 PM
Jos3ph
Feb 15, 2006 10:46 PM
PhatboyNYC
Oct 7, 2003 11:31 AM
