EF / EG Parts by the Boatload
<FONT SIZE="4">Location - Kissimmee y0! Contact - Edwin 407.375.8256 (Anytime). ALL PRICES
ARE OBO</FONT>
ALL PARTS ARE D-SERIES UNLESS OTHERWISE SPECIFIED
1) 1 SET OF D16Z6 SPARK PLUG WIRES
2) 1 EF REAR TRANSMISSION BRACKET
3) 1 EF FUEL LINE - FILTER TO RAIL
4) 1 EF REAR MAIN SEAL - BRAND NEW PLUS COVER
5) 2 D-SERIES FLYWHEEL INSPECTION COVERS
6) 1 EG DRIVER'S SIDE ENGINE MOUNT BRACKET
7) 1 P2A8 ENGINE MOUNT AND BRACKET
8) 1 D16A6 IACV
9) 1 D16A6 TIMING BELT - NEW
10)1 D16Z6 TIMING BELT - 300 MILES ON IT
11)1 ALTERNATOR BELT - 3 RIB, D-SERIES
12)4 Hub Centric Rings - 73x56.15 - Metal
13)1 EF POWER STEERING PUMP
14)1 EG POWER STEERING PUMP
15)1 MPFI INJECTOR CLIPS + ALL THE WIRING YOU SEE TO THE RESISTOR BOX
16)2 OBD-1 INJECTOR RESISTOR BOXES
17)1 OBD-0 Injector wire cover
18)1 OBD-1 INJECTOR CLIPS HARNESS
19)1 D15B7 INTAKE MANIFOLD
20)4 OBD-1 INJECTORS
21)1 D15B7 FUEL RAIL + FPR
22)1 D16A6 INTAKE MANIFOLD
23)1 D16A6 FUEL RAIL + FPR
24)1 EG ALUMINUM AC BRACKET
25)1 D15B7 WIRE HARNESS COMPLETE
26)1 1 WIRE OXYGEN SENSOR
27)3 D-SERIES VALVE COVERS
28)2 D16A6 CAMSHAFTS + GEARS
29)1 D16A6 Distributor
30)4 P28 Pistons - Attached to rods but the rods spun bearings
31)3 Alternators (2 OBD-1 1 OBD-0)
32)4 PM6 PISTONS & RODS
33)4 AC LINES - EF CHASSIS
34)1 AC CONDENSOR - EF
35)1 AC EVAPORATOR - EF
36)1 AC BLOWER - EF
37)1 AC FAN - EF
38)1 AC COMPRESSOR - EF - SANDEN
39)1 AC COMPRESSOR - EG - MATSUSHITA
40)1 D15B7 DISTRIBUTOR
Modified by dr_latino999 at 9:05 PM 1/15/2006
ARE OBO</FONT>
8) 1 D16A6 IACV
36)1 AC BLOWER - EF
37)1 AC FAN - EF
HEY CHILDREN, for the next 20 minutes, till 4PM EST I will sale the catch can with everything for 40 and the header for 50. Have a wonderful day, not a second later.
DX Cable transmission - Sold - Crimson_Tide
