Rev Hard Intake Manifolds - Finally In Stock - $295 Shipped - B16/B18
Good news. Rev Hard intake manifolds are finally here. $295 Shipped in the US 48 States.
This new Honda intake manifold is designed for the Honda/Acura B16/GSR/Type R heads. The unique bolt pattern and coolant passage is designed to fit both bolt patterns of the head. There is no need to worry about buying a new intake manifold when swapping between the B16 and GSR heads. This new intake manifold with its revolutionary design is meant for the high performance race engines of today. It features square ports to guide the incoming air straight into the head. A universal Intake Air Control bracket also makes it possible to use any Intake Air Control unit. Also includes 65mm port matched throttle body opening and 4 additional bosses for adding nitrous foggers or extra fuel injectors. This is the same intake manifold that is used on Rev Hard's 750 whp 9 second drag race Civic.
Part: B16/GSR Acura/Honda Intake Manifold
Part Number: RHA-900INTGB
Application: Honda B16/B18C Heads
Material/Forging: Cast Aluminum
what are we looking at for a power gain on these bad boys? Any info on them yet? Bump for a nice IM.
Rev Hard claims it has only been tested on their race car, but will show 10+ WHP and 8+ Ft Lbs on a low boost turbo application. The more boost you push into your system the more of a gain you will see using this manifold.
Hope that makes sense...
Did you see that it has the bosses for 4 additional inuectors. Make tuning for street use much easier!
Let me know if you have any further questions.
Jesse @ http://www.Turbo-Kits.com
Any interest? How about feedback?
If we could get 5 orders, we could do a groupbuy price $260 each.
z06eateR
Oct 5, 2009 09:05 AM
