ALTERNATOR HELP !!!
Old Dec 22, 2005 | 09:30 AM
RA61825's Avatar
Default ALTERNATOR HELP !!!
ok ive been trying to remove the alternator for a while now. it doesnt come up through the top. it hits withe the master cylinder. And it doesnt come out through the bottom either. help whats the fastest way to remove it. i have a 90 civic hatch si with a d series swap . thnx
Old Dec 22, 2005 | 09:34 AM
drdisco69's Avatar
Default Re: ALTERNATOR HELP !!! (RACERX72)
I usually take out the axle. But then again, I'm using a lift and air, so....
Old Dec 22, 2005 | 09:37 AM
headhunter's Avatar
it comes out the bottom, remove the plastic guard and it should come down through there. haven' t done it in a while , but i did mine yesterday on a DA integra and had to remove the axle, that was a bitch, especially in freezing cold.
Old Dec 22, 2005 | 10:11 AM
ghost_ryder35's Avatar
i take it out the bottom of mine without remvoing the axel... you just gotta position it right and make sure to remove the mounting braket from it!
Old Dec 22, 2005 | 10:21 AM
91-lsvtecsi's Avatar
Default Re: ALTERNATOR HELP !!! (ghost_ryder35)
remove the master cylinder its way faster
Old Dec 22, 2005 | 10:38 AM
Tyson's Avatar
out the bottom. no need to touch the axle.
rotate the alternator with the pulley facing up and the bottom facing out. it slides out that way perfectly like the solution to a puzzle.
Old Dec 22, 2005 | 11:34 AM
RA61825's Avatar
Default Re: ALTERNATOR HELP !!! (Tyson)
hey guys i took off the braket and still theres no space it hits the axle im running a sohc zc vtec on my hatch i just think because the chassis is different, my frind has the same motor on his 93 coupe and it just comes out through the bottom. i think im going to have to remove the master cylinder. Do you know if im going to have to bleed my whole brake system again?
Old Dec 22, 2005 | 11:52 AM
drdisco69's Avatar
If you unbolt the lines, you'll have to bleed the system. That's why I take out the axle. You may be able to bend the lines and not take them off, but I've never done it, so don't listen to me.
Old Dec 22, 2005 | 12:12 PM
Tyson's Avatar
if youre going to bring it out up top, youre supposed to unbolt the master cylinder, not the lines. you wont have to bleed the system, supposedly.
Old Dec 22, 2005 | 12:22 PM
RA61825's Avatar
ok i unbolted the 12 mm bolts that go to the booster but it still doesnt clear and i dont want to put any stress to the brake lines. so im thinking of taking the 2 10 mm bolts that go to the master cylinder and then taking off the master cylinder.
Old Dec 22, 2005 | 12:24 PM
Tyson's Avatar
i dont recommend taking off the brake lines.... just bend the lines enough to fit the alt.
do you even have a flarenut wrench?
Old Dec 22, 2005 | 01:02 PM
RA61825's Avatar
yes i have a flarenut wrench. ive trie jsut bending the lines but im being a biotch about it i dont wanna breake them or pinch the metal lines
Old Dec 22, 2005 | 01:04 PM
Tyson's Avatar
brake lines are pretty durable.
91akira
Aug 15, 2017 05:12 PM
david420
Aug 2, 2012 04:29 PM
jeddy0120
Nov 8, 2007 06:55 PM
tigueremalo
18
Jun 2, 2007 11:41 PM
'88civic
Nov 3, 2002 06:51 AM
