need hewlp asap crank position sensor
i checked my engine code it gave me 4 so i checked codes and it told me crank position sensor i have a 98 integra rs were is the crank sensor and why does my car idle at 1500rpm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by one_crazy_integra »</TD></TR><TR><TD CLASS="quote">i checked my engine code it gave me 4 so i checked codes and it told me crank position sensor i have a 98 integra rs were is the crank sensor and why does my car idle at 1500rpm </TD></TR></TABLE>
The Crankshaft Position Sensor (CKP Sensor) is located in the distributor housing assembly and really isn't considered a "servicable" part because there isn't a replacement part for it other than a Distributor Housing Sub-Assembly. The CKP isn't sold separately. Unless you're real good with electronics and how it works and can repair it yourself. The CKP determines the timing for the fuel injectors and ignition and also monitors engine speed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B »</TD></TR><TR><TD CLASS="quote">Len is that what I'm thinking of when you have to replace the whole distributer assembly. I've had to do this on another car before. It's not servicable like the coil and ignitor.</TD></TR></TABLE>
They jam the TDC/CKP/CYP into that sub-assembly. LoL No clue why neither.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len »</TD></TR><TR><TD CLASS="quote">
They jam the TDC/CKP/CYP into that sub-assembly. LoL No clue why neither.</TD></TR></TABLE>
Yup, exactly what I was thinking
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B »</TD></TR><TR><TD CLASS="quote">Yup, exactly what I was thinking</TD></TR></TABLE>
Have you ever tried looking at it to see perhaps if it is something that could be easily fixed.
I know we have had alot of problems with our Main Fuel Relays. Basically over years the contacts on it wears out and it can easily be fixed by removing the relay, disassembling it and resoldering the contacts on the back.
