stock 94 civic hatchback cx 1.5sohc
Old Dec 22, 2005 | 01:05 AM
moonraker's Avatar
Default stock 94 civic hatchback cx 1.5sohc
does any one know and tips or trick or parts i can put in to make my ride faster because right now its slow so i would be thankful if u guys could help me out.
Old Dec 22, 2005 | 01:14 AM
CTR-GSR's Avatar
Default Re: stock 94 civic hatchback cx 1.5sohc (moonraker)
MOTOR SWAP
Mini-Me
Search at the top of the forum under "what swaps are available..."
Old Dec 22, 2005 | 03:05 AM
civiccoupe94's Avatar
just keep that motor since gas is expensive. cheaper regular fuel + good gas mileage = super savings. other than that the only way you get power is a motor swap or a mini-me like what CTR-GSR said.
If you dont want to go that route/short on cash, you can start off by i/h/e, lighter wheels, take stuff that you dont need out of car, etc to make the car go a little faster
Old Dec 22, 2005 | 03:27 AM
ReDHaTcHyGuy's Avatar
Default Re: (civiccoupe94)
u can also swap a ex/si trans also , makes a huge difference.. better yet get a 96-00 ex trans cause they have steel shift forks ,, 92-95's have aluminum and they have been know to break
Old Dec 22, 2005 | 03:28 AM
sohc_boy's Avatar
92-95 ex/si or 96-00 ex tranny swap, best bang for buck mod. also look up mistabone he's done quite a bit of tinkering with the 1.5, there are quite a few oem upgrades you could do. 4th gen si cam swap, z6 or y8 intake manifold swap, z6 or y8 exhaust manifolds (the 00 is the best). most of these things can be found pretty easily and cheaply. depending on what you want to do you can go alot further obviously.
Old Dec 22, 2005 | 04:38 AM
CTR-GSR's Avatar
Default Re: stock 94 civic hatchback cx 1.5sohc (sohc_boy)
aww. If your car was EK I had some springs to sell for you moonraker
Old Dec 22, 2005 | 04:55 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Normally I have some suggestions even for stock engines, but the 70hp 8-valve CX engine is total ****.
I'd at least try and find a good 92-95 Civic DX 1.5L D15B7, or better yet perhaps round up an old 88-91 Civic/CRX Si D16A6 in good shape and drop it in. They have 106hp stock compared to your 70hp. You can probably find damn near FREE D16A6 or D15B7 engines due to their low demand and the fact that people junk them after going with the B, H, or K series engine swaps.
BTW:
Best band for the buck mod would be an EX/Si transmission swap - the CX has the tallest gearing and tallest final drive, which means it takes forever to power through each gear and the rpm drops too far when shifting into each gear.
Old Dec 22, 2005 | 07:04 AM
sohc_boy's Avatar
Default Re: stock 94 civic hatchback cx 1.5sohc (B18C5-EH2)
my bad i thought the cx had the b7 in it.
Old Dec 22, 2005 | 12:47 PM
97spooncivic's Avatar
i disagree with everyone. i would say the best bang for the buck is nitrous. blow your motor and get a cheap swap like a b18b. then start working from there. my 2 cents though
Old Dec 22, 2005 | 01:45 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: stock 94 civic hatchback cx 1.5sohc (97spooncivic)
70hp CX engine + nitrous = still slower than a stock Dx engine and may last a few weeks at best.
Old Dec 22, 2005 | 03:31 PM
EJ1 94's Avatar
SWAP
Old Dec 22, 2005 | 04:26 PM
SUPERSONICGSR99's Avatar
Swap it qwuik, I have a 92 CX ran like 20sec. 1/4 mile run, put a D16Z6/Si tranny and some bolt ons and now I run 15.3s all day.
doug118
Apr 8, 2016 09:18 AM
fejvtec
Aug 6, 2009 05:56 PM
ieatrice
10
Feb 15, 2006 11:13 AM
dragonjay006
May 3, 2004 10:01 AM
Nothing.Special
May 11, 2003 09:07 AM
