b16 pulley vs b20 pulley
Old Dec 21, 2005 | 11:30 PM
( o )( o )'s Avatar
Default b16 pulley vs b20 pulley
quick question:
I need a new crank pulley for my b16. This guy down the street has one from a b20. are they the same? will it work? thanks!
Old Dec 22, 2005 | 01:31 AM
fmrprojects's Avatar
Default Re: b16 pulley vs b20 pulley (( o )( o ))
yeah it will work but you might have to use a b20 alternator belt
Old Dec 22, 2005 | 03:59 AM
StorminMatt's Avatar
The B20 pulley is larger, but will likely work with a longer belt.
Old Dec 22, 2005 | 09:22 AM
DavidR's Avatar
It will probably overdrive your alternator, and wear the bearings out faster, too. On the flip side, your AC will work better at idle since the pump will be turning faster.
Old Dec 22, 2005 | 10:41 AM
( o )( o )'s Avatar
Default Re: b16 pulley vs b20 pulley (DavidR)
HMM....not sure I want to risk damaging other components. How much bigger is it? anyone got pics or measurements?
Old Dec 22, 2005 | 07:13 PM
DavidR's Avatar
I have set it up to the B16 one, and it is noticably bigger on the alternator side, at least .75" in diameter more.
smokinsi
Sep 23, 2005 10:21 AM
PanamaVTI
May 23, 2004 06:32 AM
nominous
Sep 3, 2003 03:46 AM
Westrock2000
Jan 7, 2003 03:10 PM
dlric
Mar 13, 2002 10:36 PM
