which half shaft and axles do i use? really confused here. please help.
so i just swapped in a 1st gen b16 into my ek9, everything is converted, wired, and running obd1 with a p28 ecu. everything is good except it cant move cuz i cant find the right axles to use. i bought a half shaft from a friend, came off a b series block, but doesnt bolt up to my block.
if i have an obd0 block but im running a gsr hydro trans, do i need to use a half shaft from a hydro or cable trans?
not sure cuz my block came with a cable trans, but im not down with my ek having cable trans.
also i bought some 99-00 civic si axles. on the drivers side axles one side is male and one side is female. kinda confused cuz the half shaft is female... dont know what to do. and the pass. side axle seems too short, cuz i put the axle in the trans then put the axle nut on, thought i was done then looked from the top and had a 1-2 inch gap between the axle and trans?
some people told me to run a del half shaft with 94+ gsr axles?
is this true.
i just wanna know so i dont waste anymore money.
please help...
thanks
rob
is this true.
please help...
thanks
rob
Run a 94+ Integra halfshaft. Then you can use Integra axles.
If you want to use the halfshaft you already have, you can probably use 90-93 Integra axles. Although this is just a guess.
JustAnotherRex
Jan 9, 2009 05:29 PM
=ITRpoweredEK9=
Dec 29, 2005 06:22 AM
