this weeks dilemma: car wouldnt start after getting gas..later shuts off while driving
Old Dec 21, 2005 | 06:49 PM
. M i c h a e l's Avatar
dotmichael to you
Default this weeks dilemma: car wouldnt start after getting gas..later shuts off while driving
well, i took my car out tonight to get gas and drop it off at a shop to have the car checked out.
i got gas, filled up and went to start the car. it wouldnt start. i cranked about four times in five minutes and it finally started.
i got on the road driving to the shop, i was doing about 55 and the car just shut off. i pulled over to the shoulder and after cursing a bit, cranked once and it started up.
drove 10 more minutes to the shop and the car gave me no other problems.
i'm thinking distributor, how bout you guys?
Old Dec 21, 2005 | 06:58 PM
dadriver's Avatar
Default Re: this weeks dilemma: car wouldnt start after getting gas..later shuts off while driving (. M i c
i gunna say mtl becuase i had the same prob once and the dizzy ****
Old Dec 21, 2005 | 07:29 PM
Mt3c's Avatar
25 Year Member
whats the mtl?
as for the car not starting at the gas station, that sounds like the main relay.
Its a 40-50 dollar relay, and worth replacing on older hondas. I've had the "no start after getting gas" for a long time, replaced main relay, fixed that problem.
Search "main relay" and you will know exactly why it fails.
as for the car shutting down while driving, and restarting right afterwards, I've never been that lucky.
Old Dec 21, 2005 | 07:32 PM
thatHEMIguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mt3c &raquo;</TD></TR><TR><TD CLASS="quote">whats the mtl?
as for the car shutting down while driving, and restarting right afterwards, I've never been that lucky.</TD></TR></TABLE>
yep, thats what it is. did it in mine also. just going down the road and it would stop... wht you need to do is listen to see if the fuel pump turns on... if not, then its most likely the relay
Old Dec 21, 2005 | 07:35 PM
dotmichael to you
you know..i thought it might be the main relay as well.
any way to check it out? i've heard some people solder the connections
Old Dec 21, 2005 | 07:36 PM
dotmichael to you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonerboner95 &raquo;</TD></TR><TR><TD CLASS="quote">
yep, thats what it is. did it in mine also. just going down the road and it would stop... wht you need to do is listen to see if the fuel pump turns on... if not, then its most likely the relay</TD></TR></TABLE>
i listen for the fuel pump each time i start my car. habit. its fine
Old Dec 21, 2005 | 07:41 PM
dotmichael to you
also..where the hell IS the main relay? the car is at the shop so i cant check it out right now. if memory serves me correct..its by the fuse box?
most importantly...are any of these interchangable like the TPS is?
Old Dec 21, 2005 | 07:45 PM
96ls's Avatar
devil car!!!
i swear this thing is posessed. but anyway, the main relay sounds like a good starting point
Old Dec 21, 2005 | 08:13 PM
dadriver's Avatar
MTL......MORE THEN LIKELY.....but ahh i had a dizzy **** like that on the highway once like that then it started then die then started agiain then died then again started then died...but any way some times my fuel pump dont work too wtf......WHAT THE expletive... if i change the main relay ya think that would fix the fuel pump that doesnt kick on some times
Old Dec 22, 2005 | 05:32 AM
the mair relay is on the drivers side on the left behing the kick pannel. it is bolted to a bracket and there are two different relays and if im correct the main relay is on the back side. also, the main relays are only interchangable in the 90-93 integras. ive tried to use a eg and ef main and they dont work.... yes people have solder them, but i just find it easier to just find one at a junk yard and/or buy a new one
Old Dec 22, 2005 | 08:59 AM
R6E6I6D's Avatar
My mainrelay went bad and the back of the circuit board (took it apart) was all coated in brown sealant (normal) but some spots were black and burnt (not normal)
and for the car dying Id have to say it could be a number of things
crank position
igniter
coil
fuel pump
PGMFI relay
dizzy cap and rotor &lt;- this how mine broke
even a fuel filter can eventully choke a car
well best of luck to u but First check PGMFI relay
Old Dec 22, 2005 | 04:46 PM
dotmichael to you
picked it up from the shop, car turned on first turn. (hadnt been on in over 6 hours) and i drove it 20 minutes home. no problems.
so its not something that'll happen each time. ugh.
Old Dec 22, 2005 | 05:32 PM
main relay will do that to you. i went about 3 weeks then it started again
Old Dec 22, 2005 | 05:58 PM
Cliffjumper2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R6E6I6D &raquo;</TD></TR><TR><TD CLASS="quote">My mainrelay went bad and the back of the circuit board (took it apart) was all coated in brown sealant (normal) but some spots were black and burnt (not normal)
crank position
igniter
coil
fuel pump
PGMFI relay
well best of luck to u but First check PGMFI relay </TD></TR></TABLE>
sounds about right
it's also possible your teg has electrical gremlins, and by that I mean a short somewhere.
Old Dec 22, 2005 | 06:09 PM
dotmichael to you
crank position
igniter
coil
fuel pump
PGMFI relay
crank position- wha?
igniter,coil,dizzy cap/rotor- i know the cap is new. any way to really check the other stuff? i mean this isnt happening all the time and no one has a dizzy i can borrow.
fuel pump primes every time.
i've never even heard of the PGMFI relay
Old Dec 22, 2005 | 06:11 PM
http://www.tegger.com/hondafaq/mainrelay.html
Old Dec 22, 2005 | 07:06 PM
dotmichael to you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by http://www.tegger.com/hondafaq/mainrelay.html &raquo;</TD></TR><TR><TD CLASS="quote">The Main Relay will click three times during the starting process. When problems arise, one of those clicks (usually the third) is missing, making those clicks a handy diagnostics tool. If you consistently hear/feel all three clicks, the Relay is fine. DO NOT REPLACE IT.
Turn ignition to ON (but not to START): Click 1
Check Engine light goes off: Click 2
<FONT COLOR="red">You now turn the key to START: Click 3</FONT></TD></TR></TABLE>
refer to the red. it says turn key to start..do they mean start the car, or turn the key all the way as if i was starting the car?
i hear the first two clicks..and the fuel pump primes..but when i turn the car on, its too loud to hear a third click
Old Dec 23, 2005 | 01:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by . M i c h a e l &raquo;</TD></TR><TR><TD CLASS="quote">
refer to the red. it says turn key to start..do they mean start the car, or turn the key all the way as if i was starting the car?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by . M i c h a e l &raquo;</TD></TR><TR><TD CLASS="quote"> turn the key all the way as if i was starting the car</TD></TR></TABLE>
you got it
Old Dec 29, 2005 | 08:18 PM
dotmichael to you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cliffjumper2 &raquo;</TD></TR><TR><TD CLASS="quote">
you got it </TD></TR></TABLE>
i get clicks one and two..i turn the key all the way after the fuel pump has primed and everything goes quiet..no clutch or anything..and i dont get a click..it just turns.
ls19integra95
Dec 25, 2007 04:58 PM
MulletManRockStar
11
Sep 19, 2004 02:44 AM
hatchy
Apr 3, 2003 06:50 PM
Louie B.
Aug 7, 2002 06:46 PM
