broken studs ...need help
Old Mar 17, 2002 | 04:31 PM
slowassR's Avatar
Default broken studs ...need help
A friend of mine managed to break three out of four wheel studs, dont know how. we have taken the rotor and caliper off but we are having trouble getting the old studs out. please understand we are just learning.
My question is: Does any one have online directions showing how to change wheel studs on a Honda, specifically a 2000 civic.
Old Mar 17, 2002 | 04:41 PM
DR. ON POINT's Avatar
Banned
Default Re: broken studs ...need help (slowassR)
take the rotor off and all u should see is a spindle with the broken studs sticking out...wack the broken studs with a hammer...they will come out...if they dont come out first try keep doing it......next put the new studs in and push them in somewhat snug(ur not pushing them to go into the hole completly u are pushing them in so they dont fall back out when utting on the new rotor)...put the new rotor on and put some washers on the stud..than put the lug nut on and tighten and losen and than tighten and losen about 400 times (exageration).....it works best with a air gun....the studs should be set in place...put everything back on correctly pull the car out of the driveway make sure the brakes work and than do a burn out ...I use to do this about 2 or 3 times a day at my old job
Old Mar 17, 2002 | 04:52 PM
slowassR's Avatar
thank you very much, i guess we just need to give them a good hit. thank you again, i love this message bord stuff :0)
Old Mar 17, 2002 | 04:54 PM
Banned
im glad I can help someone out...I have received so much help from here too
Old Mar 17, 2002 | 04:55 PM
slowassR's Avatar
very cool Dave :0 ) ill let you know how it goes.
Old Mar 17, 2002 | 05:14 PM
slowassR's Avatar
ok, just talked to my budd, he says that hes is having problems getting the hub absembly off and that is blocking the bolts from being pushed through. does that make any sence?
Old Mar 17, 2002 | 05:16 PM
slowassR's Avatar
"you gotta ake the whole hub absembly apart, and thats what i don't know how to do"...
Old Mar 17, 2002 | 05:17 PM
Banned
is this the front or the rear?
Old Mar 17, 2002 | 05:21 PM
slowassR's Avatar
front driver side
Old Mar 17, 2002 | 05:23 PM
Banned
u need to take the caliper off...I think its a 12mm...slide the caliper off than remove the brake pads and than remove the 2 screws holding the rotor on..it should just come off afeter doing that...if the rotor is stuck on wack it with a rubber maled
Old Mar 17, 2002 | 05:32 PM
slowassR's Avatar
do you have aol?
my buddy says " you cannot remove the studs becuase there is steel behind them
WILLYDAWSON V: you have to remove the hub assembly to be able remove the studs "
Old Mar 17, 2002 | 05:33 PM
Banned
look at my sig
Old Mar 17, 2002 | 05:38 PM
Phantom's Avatar
BUY A HELMS MANUAL
those caps were not a mistake.
Old Mar 17, 2002 | 05:39 PM
slowassR's Avatar
are you talking about the " " by ganstar?
Old Mar 17, 2002 | 05:45 PM
slowassR's Avatar
how stupid are we, get the direction
Old Mar 17, 2002 | 07:32 PM
JaeOne3345's Avatar
never undo lug nuts when they r still hot. and try not to use air wrenches
Old Mar 17, 2002 | 09:24 PM
mingchi96
Guest
Posts: n/a
Default Re: broken studs ...need help (JaeOne3345)
save yourself the trouble and go to NTB and just pay them $50 to do it. If you really want to do it yourslef, you need a machine press and press the hub off, then hammer the studs off and put the new one on, and press the hub back on. Its a lot easier if you just take off your front spindle.
I usually do work myself, but something like this, I would just pay an alignment shop to do.
Old Mar 17, 2002 | 09:36 PM
lucas569's Avatar
Default Re: broken studs ...need help (mingchi96)
ok normally on most cars all you do is remove the rotor and hammer the old ones out, on the freakin hondas you have to press out the bearing cause theres a lip there blocking it, you wont be able to get the studs on trust me. if you try to remove the bearing by hammering it out it will screw the bearing up cause its a sealed unit. then you will need to replace it if you go that route and still have to have the thing pressed in no matter what. best cheapest method is to remove the front fork and bring it to the dealer. otherwise theyre going to hit you up for like $250+
Old Mar 18, 2002 | 10:13 AM
slowassR's Avatar
sounds good guys, we took your advice and brought it to a shop and they removed the hub, gave it a good hit and the studs came right out, thanks again very much ...Luke
JSA
Honda Civic (2006 - 2015)
Apr 7, 2011 02:05 AM
timmy0tool
10
Dec 19, 2007 03:25 PM
Hasboro
May 18, 2004 08:30 AM
dynamo
Sep 20, 2002 11:37 AM
slowassR
Mar 18, 2002 10:09 AM
