can i keep my ac with this manifold please help
i just bought this sparks racing manifold 3 " dp and garret t3 60-1 turbo from my friend
he was not running ac and had the compressor on the driver side. i switched turbo so the compressor is on the passanger side.
i really want to keep ac and there really does not look like there is any room. the dp is 3" will a 2.5 dp work. by the looks of it it look like there is only 2.5 inches from thr turbo to the ac compressor
does anybody have pics of a sparks racing or ssac manifold with ac
also are you supose to run a gasket between the manifold and the turbo??
will a 2.5 dp work. cus i dont even this a 2.5 dp will work
and how bad will a 2.5 dp affect a 500hp car
its a very tight fit but its possible to run a 2.5" downpipe with that manifold. on mine i had to make a very sharp turn right off the flange to clear the a/c compressor.
you cant see from this angle to well but it does come close to the compressor and since it has such a sharp turn off the flange its really hard to put in the bottom two bolts on the flange.
i custom made that downpipe myself but if you have a good fabricator im sure they can make a much better downpipe.
i would just ditch the AC or get some slim fans for sure. that is gonna be a real tight fit with a t3/60-1. you'll definitely need a new downpipe. i think 2.5 will be ok.
your manifold looks really close to a ssac one.....
