Draft: ebay intake install questions...b16/ef....with pics
Old Dec 21, 2005 | 03:55 PM
drew2's Avatar
Default ebay intake install questions...b16/ef....with pics
I bought a cheapo intake off ebay, im not sure what to do w/ all the vacuum lines
The intake only has one vacuum line. This vacuum line should go from G to H.
As i understand it, I should remove the two dashpots A and B.
What about vacuum lines C and F? Just remove them and leave it open?
What about the opening in the intake manifold where B used to be?
Finally, i bought an EF intake but i have a b16 swap, the intake doesnt quite fit in the engine bay, anyone else had this problem? I was just going to cut a few inches off the end where the filter goes,
As the picture shows, the intake is close, but doesnt quite fit
Old Dec 21, 2005 | 04:11 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: ebay intake install questions...b16/ef....with pics (drew2)
Run a hose straight between valve cover and intake:
Run a hose straight from intake to throttle body:
Thus eliminating the plumbing and excess hoses
Remove dashpot A leave Dashpot B in place...
Old Dec 21, 2005 | 09:05 PM
drew2's Avatar
Default Re: ebay intake install questions...b16/ef....with pics (88DXCRX)
alright, for the second hose do you mean from the thermostat to the throttle body? (its a coolant hose right?)
if so im with you now
pjr710
23
Jun 10, 2007 09:58 PM
Jesterian
Oct 3, 2005 04:17 PM
Knight1
Sep 16, 2005 11:44 AM
drew2
Aug 28, 2005 08:55 PM
