taillight fuse keeps blowing
Old Dec 21, 2005 | 03:38 PM
abda53's Avatar
Default taillight fuse keeps blowing
my passenger fender/right side of the bumper was hit slightly, and ever since then my passenger light fuse keeps blowing. is there anything around the passenger side fender (grounds, etc) that are related to the taillights that could be causing this?
Old Dec 21, 2005 | 04:20 PM
RedKroovy's Avatar
Default Re: taillight fuse keeps blowing (abda53)
I personally have never seen any grounding points in that area. Have you inspected the pieces that hold the lights themselves maybe the wires are touching there. After that I have no idea.
Old Dec 21, 2005 | 04:24 PM
abda53's Avatar
ill take a look at that tomorrow..
Old Dec 21, 2005 | 05:39 PM
Chris F's Avatar
Default Re: (abda53)
Happened to me once, it was the horn. Same fuse. good luck...
Old Dec 22, 2005 | 08:08 AM
abda53's Avatar
Default Re: (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">Happened to me once, it was the horn. Same fuse. good luck...</TD></TR></TABLE>
horn works fine.. fuse only blows when the lights are turned on. still havent had a chance to look at it though..
Old Dec 22, 2005 | 08:16 AM
Arsenal's Avatar
there are bare wires hitting in that area. take alook under there and look for loose wires ect
Old Dec 22, 2005 | 08:21 AM
migs's Avatar
Default Re: (Arsenal)
There are grounds in that area and I bet you a wire is getting a cross connection. Check for damaged wires.
Old Dec 22, 2005 | 09:15 AM
len's Avatar
len
Send me an email and I can get you a .pdf document for the wiring so you can go back and check every single wire.
Old Dec 22, 2005 | 09:23 AM
abda53's Avatar
Default Re: taillight fuse keeps blowing (len)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len &raquo;</TD></TR><TR><TD CLASS="quote">Send me an email and I can get you a .pdf document for the wiring so you can go back and check every single wire. </TD></TR></TABLE>
not sure how to email you on here... ? and your IMs are off.
could you please email it me? abda53com[at]yahoo
Old Dec 22, 2005 | 09:28 AM
len's Avatar
len
https://honda-tech.com/zerothread?id=1426478
Old Dec 22, 2005 | 02:59 PM
abda53's Avatar
update..
i took the back panels off.. (btw i REALLY love the plastic screw/connector things they used!)
no wires getting grounded out.. no open wires.. nothing looked wrong.
still not sure. i did test it, by putting a 15 in there to see if it would even come on with that, but then the 15a +b small / +b lanternes fuse in the main box under the hood blew..
im not sure what everything goes to that fuse.. and im not sure if that helps narrow it down any at all..
any ideas? im about to call a shop and see if they can fix it, because i really need those taillights to drive at night
Old Dec 22, 2005 | 03:19 PM
Arsenal's Avatar
No, the wires at the front bumper, check those and the related sub harness, particulary where the car was hit
Old Dec 22, 2005 | 03:25 PM
abda53's Avatar
ok. ill do that tomorrow morning since its getting dark outside now.
thanks
Old Dec 23, 2005 | 02:23 PM
abda53's Avatar
pulled the fender off, and the bumper.. i checked all the harnesses, wires, connections, i didnt see anything that looked messed up. i did notice, the bumper lights, the two outside lights (not the turn signals.. maybe the running lights?) those werent turning on, and the bulbs didnt look bad. i checked the fuse, and it was blown, but i replaced it, and it still wasnt turning on (but the fuse was fine after that).. im not sure if its related or not. but i did knock out most of the dent in the fender from what i got hit, so i guess that was good.....
if there is someone in san diego that can help me fix this fuse problem... ill pay you like $100 or somethin.. i REALLY need it fixed
Old Dec 23, 2005 | 11:54 PM
eeeKs's Avatar
i got the same problem ..
happens now and again
Old Dec 24, 2005 | 12:38 AM
abda53's Avatar
now that i think about it.. it blew a few days after i had bought it.. but it worked fine after i replaced the fuse.
i wonder if theres any way to jerry-rig it for the time being so that the tail lights will have power (even if its on during day driving)
Old Dec 24, 2005 | 05:26 AM
Bbasso's Avatar
Since you know there is a short, Do Not put in a bigger fuse.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">A safety device that protects an electric circuit from excessive current, consisting of or containing a metal element that melts when current exceeds a specific amperage, thereby opening the circuit.</TD></TR></TABLE>
Also, It could be the socket for the bulbs, get the tester out and see if there is continuity. that would be bad.
Old Dec 24, 2005 | 08:58 AM
abda53's Avatar
not possitive that it is a short, but im guessing that it is.. over a bad ground.
n00b question.. how do i do that?
Old Dec 24, 2005 | 10:31 AM
abda53's Avatar
quick question...
the running lights, are they constantly on when the headlights are on? do they alternate when the blinkers are on?
tdubbebawllin
Jul 29, 2008 01:34 PM
sagron69
12
Dec 30, 2005 05:07 PM
reallycooleg
Jul 10, 2005 07:20 AM
GReddy212
Apr 12, 2005 10:56 AM
Si_Power
Jun 23, 2003 08:12 AM
