D15b auto rear main seal replacement help
Old Dec 21, 2005 | 03:06 PM
Cuong-nutz's Avatar
Default D15b auto rear main seal replacement help
Is the rear main seal the same for a VX?
Do I need a special tool to remove those bolts holding the flex plate onto the crank?
Old Dec 22, 2005 | 08:31 AM
Cuong-nutz's Avatar
Default Re: D15b auto rear main seal replacement help (Cuong-nutz)
Anyone know?
Old Dec 22, 2005 | 08:39 AM
boostedcivicsir's Avatar
Mr. Badwrench
i dont know if the seals are the same or not but, all you need is a 17mm 12 point to take off the flex plate off of the crank.
Ricey McRicerton's Avatar
Default Re: D15b auto rear main seal replacement help (boostedcivicsir)
To get my rear main seal out I just took a small drill bit, and put some indentions in the seal, put some screws it in and yanked it out that way.
Old Dec 22, 2005 | 08:41 AM
Cuong-nutz's Avatar
Default Re: D15b auto rear main seal replacement help (Ricey McRicerton)
Thanks for the tip
Old Dec 22, 2005 | 11:52 AM
Mr. Badwrench
just be very careful not to nick the seal surface of the crank, unless you feel like putting in a crankshaft. ricey's method is old school too. i was tought that a long time ago. i still use a small flat blade.
djfob
Dec 6, 2011 03:14 PM
McDonagh
Sep 21, 2008 10:45 AM
hondaapi
Jan 7, 2008 09:20 AM
elmo908
Apr 15, 2007 04:35 PM
JCracer723
12
Jun 13, 2003 12:14 PM
