Help with ignition switch swap
Old Dec 21, 2005 | 01:38 PM
95excoupe's Avatar
Default Help with ignition switch swap
My ignition just went out and I have one from a 93 civic ex automatic I could use. The problem is my car is a manual. Is there any diffferences and do I have these shear off bolts or it just normal ones?
Old Dec 21, 2005 | 02:30 PM
95excoupe's Avatar
Default Re: Help with ignition switch swap (95excoupe)
BUMP. I need info by tomorrow
Old Dec 21, 2005 | 02:58 PM
Echo7847's Avatar
I cant find the part # so I cant check if theyre the same but instinct tells me they should be.
All you need to do is remove the upper steering column covers and the switch will be on the left side of the wheel. 2 or 3 small phillips screws and the switch comes off, *minus a few connectors).
You're just replacing the electrical portion correct?
Old Dec 21, 2005 | 03:08 PM
95excoupe's Avatar
Default Re: Help with ignition switch swap (Echo7847)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echo7847 &raquo;</TD></TR><TR><TD CLASS="quote">I cant find the part # so I cant check if theyre the same but instinct tells me they should be.
You're just replacing the electrical portion correct?</TD></TR></TABLE>
I am not sure exactly what to change. The problem is after the car is started, if I release the key it will shut off, and if I hold the key forward it stays on. I am assuming that is something to do with the actual switch? I can take whatever I need as far as ignition goes from the parts car so I am just wondering what I will need. I heard the automatic has some kind of ring around it though to prevent you from taking the key out when it's not in park? Just wondering what im getting myself into for tomorrow
Old Dec 21, 2005 | 04:01 PM
95excoupe's Avatar
bump
Old Dec 22, 2005 | 01:00 PM
95excoupe's Avatar
Incase anyone looks this up. If you are having the same problems as I had all you have to do is pop off that white cap and clean the terminals with some sandpaper. Mine had oxidation on them, but nothing that seemed like an electrical problem. It seemed like more of a weather and age problem. The one terminal that keeps the car on after you bump the starter was so corroded that it was losing the connection, so now that it's clean it runs perfect again
Old Dec 22, 2005 | 01:06 PM
d16y8hatch's Avatar
hey i'm from jersey too. relax, i had this problem with my hatch, you have to remove the steering column panels. you'll see on the left side a white round plug with a harness attached to it which leads to a brown plug underneath the dash. you have to really get under t here to find it but it's not that hard. you're lucky you
found just the electrical part of it since it's only sold together with the key cylinder 200 bucks only from honda. live and learn
Old Dec 22, 2005 | 01:15 PM
95excoupe's Avatar
Default Re: Help with ignition switch swap (d16y8hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16y8hatch &raquo;</TD></TR><TR><TD CLASS="quote">hey i'm from jersey too. relax, i had this problem with my hatch, you have to remove the steering column panels. you'll see on the left side a white round plug with a harness attached to it which leads to a brown plug underneath the dash. you have to really get under t here to find it but it's not that hard. you're lucky you
found just the electrical part of it since it's only sold together with the key cylinder 200 bucks only from honda. live and learn </TD></TR></TABLE>
Dirtay Jersay fo life!....if you look above your post you will see what I actually did. You don't need to buy a new one it was just corroded and the terminals needed to be cleaned.
Old Feb 26, 2006 | 07:15 AM
LatinEM2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95excoupe &raquo;</TD></TR><TR><TD CLASS="quote">Incase anyone looks this up. If you are having the same problems as I had all you have to do is pop off that white cap and clean the terminals with some sandpaper. Mine had oxidation on them, but nothing that seemed like an electrical problem. It seemed like more of a weather and age problem. The one terminal that keeps the car on after you bump the starter was so corroded that it was losing the connection, so now that it's clean it runs perfect again </TD></TR></TABLE>
i have the same problem...95 dx sedan..i cleaned like you said..but the car still dies right after starting.. ..i couldn't take out the cylinder neither..is there a trick to getting it out??
Old Feb 26, 2006 | 05:42 PM
LatinEM2's Avatar
also on my dx, when i turn the key to II nothing lights up..the car will turn on III and if i keep the key there and dont' let it come back to II it runs...help!
Old Jun 15, 2006 | 09:00 AM
eric52882's Avatar
I happened to look this thread up when my ignition switch was acting up, and I cleaned up the connections like 95excoupe said, FIXED!!! Thankyou thankyou thankyou. Saved me $350 and a bigger headache!
poprocksncoke
Apr 17, 2017 01:22 PM
LukieLuc
Apr 9, 2008 05:24 PM
Jmumblez2001
Jul 26, 2006 12:06 AM
Itzmy91Teg
Jun 29, 2006 08:24 PM
zebra_fish
Jun 13, 2006 01:38 PM
