Need Help WIth Swap
Old Dec 21, 2005 | 01:06 PM
93blkcivic's Avatar
Default Need Help WIth Swap
Ok im buying a b16 1st gen and i have a 93 civic ex i wanna know if it is possible to make that b16 0bd1? or will i have to buy the 0bd1 to 0bd0 conversion harness? cuz i thought i cud just use my 0bd1 distributor and my p28 ecu on the b16 so its not 0bd0 please help Thanks
Old Dec 21, 2005 | 02:04 PM
transpar_nt's Avatar
Default Re: Need Help WIth Swap (93blkcivic)
To convert to obd1 you'd need an obd1 distributor, injectors, wiring harness, and ecu. You can use the injectors and wiring harness from your d series, but you'll need to extend a few wires.
Old Dec 21, 2005 | 02:11 PM
93blkcivic's Avatar
Default Re: Need Help WIth Swap (transpar_nt)
so i'd have 2 get a distibutor? i thought there the same as the d-series
Old Dec 21, 2005 | 03:53 PM
T.J.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93blkcivic &raquo;</TD></TR><TR><TD CLASS="quote">so i'd have 2 get a distibutor? i thought there the same as the d-series</TD></TR></TABLE>
nope not the same, you will need a obd1 b series distributor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by transpar_nt &raquo;</TD></TR><TR><TD CLASS="quote">To convert to obd1 you'd need an obd1 distributor, injectors, wiring harness, and ecu. You can use the injectors and wiring harness from your d series, but you'll need to extend a few wires.</TD></TR></TABLE>
Old Dec 21, 2005 | 04:30 PM
EK-SI's Avatar
no you can not use that distributor and you also can not use that ecu either it will not run that motor
Old Dec 21, 2005 | 04:33 PM
Jay_Sensing's Avatar
EK-SI, you need to be a little more specific when throwing out doom and gloom.
You have to change the injectors and dizzy and everything else on there is going to snap together (if I remember right, I have done it twice but fuzzy).
You can't use a D series dizzy but you can use a B18c or B16A dizzy and if you use the P28 puter, you need to get it chipped for a DOHC engine as the redline, timing and fuel curves are all different from one another. It will run on the stock program but it won't run great.
Old Dec 21, 2005 | 06:20 PM
93blkcivic's Avatar
Default Re: (Jay_Sensing)
what wires will i need to exend? someone told me the fan wires
Old Dec 22, 2005 | 01:49 PM
Default Re: (93blkcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93blkcivic &raquo;</TD></TR><TR><TD CLASS="quote">what wires will i need to exend? someone told me the fan wires</TD></TR></TABLE>
you don't need to touch those. I can't remember exactly, you'll just have to see when you put the harness on the B. Well, I'll go look...
Oxygen sensor - 10"
Backup light switch (i think) - 10" (screws into front of tranny)
Oil pressure sender - 4" (back of block; right beside oil filter)
IAT sensor - 10" (on the right-most runner on intake manifold)
??? - 6" (I honestly don't even know what this is. A small plug that screws into the block directly below the distributor).
All of the lengths are just approximations, so don't extend them exactly that length and bitch at me if its not long enough / too long.
Modified by transpar_nt at 7:09 PM 12/23/2005
xotic_crx
May 20, 2010 08:33 AM
TegRX91
May 19, 2005 01:50 PM
-KangaRod-
Aug 10, 2004 11:42 AM
BB6-213
Jun 22, 2004 12:01 AM
