how much to mill off LS rods to fit type-r pistons?????????????????????????????????
just like topic says. i have ls rods that are a bit bigger and wont fit the piston unless they are milled on each side. does anyone know how how exactly to mill off each side
1mm per side of the rod. That would be 2mm total / OR / 0.0039 of an inch per side of the rod.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Importordomestic »</TD></TR><TR><TD CLASS="quote">EDIT: only on the small end of the rod.
only where the dowel pin goes you mean?
</TD></TR></TABLE>only where the dowel pin goes you mean?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H23vtecEG »</TD></TR><TR><TD CLASS="quote">only where the dowel pin goes you mean?</TD></TR></TABLE>
yes. the small end of the rod is the end the wristpin goes in. the big end is the end that goes on the crank journal.
It may be easier for the shop to mill the inner sides of the pistons. That's what they did with my CTR slugs to mate them with LS rods.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arw321 »</TD></TR><TR><TD CLASS="quote">It may be easier for the shop to mill the inner sides of the pistons. That's what they did with my CTR slugs to mate them with LS rods.
better also
better also
mill the piston.. not the rod... the ls rod is already weak enough why make it weaker? just my .02
shawn
shawn
TNT
12
May 11, 2007 01:46 PM
