B16a engine and tranny mounts
Old Dec 21, 2005 | 11:04 AM
gray_civic_coupe's Avatar
Default B16a engine and tranny mounts
would the mounts on my d16y8 fit if i swapped a B16a engine?
as i know i will have to change the up front engine mount and thats it, so correct me if i'm wrong...
Old Dec 21, 2005 | 11:05 AM
Lee_Delso's Avatar
Default Re: B16a engine and tranny mounts (gray_civic_coupe)
Simple answer..."NO"
/thread
Old Dec 21, 2005 | 11:22 AM
Thnx for the info
Old Dec 21, 2005 | 12:29 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: (gray_civic_coupe)
Some mounts will work. U need the trans bracket from a b16 del sol i believe. You also need a p54 ac bracket or the crv ac bracket if u plan on using your d series ac compressor
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: B16a engine and tranny mounts (Lee_Delso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lee_Delso &raquo;</TD></TR><TR><TD CLASS="quote">Simple answer..."NO"
/thread</TD></TR></TABLE>
Then y dont u give a more detailed answer? *******
Old Dec 21, 2005 | 12:45 PM
hatchi's Avatar
what year b16 engine?? the 2 top mounts can be used. the other 3 you will need off 99-00 si or 94-00 gsr
Old Dec 21, 2005 | 12:49 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: B16a engine and tranny mounts (hatchi)
i dont think the 99-00 si trans bracket works tho... i could be wrong, cant remember what one i used
Old Dec 21, 2005 | 04:39 PM
b16_DIM's Avatar
im swapping a d16y7 for a b16a, the top left and right mounts as well as the rear mount all worked fine. I'm having problems finding torque mounts though.
Old Dec 21, 2005 | 09:08 PM
thnx for the info guy
teg_95
Mar 17, 2009 04:05 AM
jackedupEK9
Sep 29, 2006 10:50 AM
SPD DMN
Sep 20, 2006 01:50 PM
Jesterian
Aug 18, 2006 01:26 AM
red civic standard
Apr 29, 2002 08:00 PM
