please help....motor cranks....doesnt fire
Old Dec 21, 2005 | 10:55 AM
ek99gsr's Avatar
Default please help....motor cranks....doesnt fire
i searched and couldnt find anything
a couple weeks ago i swaped distributors with a buddy. when i put my distributor back on that night....car wouldnt fire. was getting air, fuel, and spark. making a screetching noise when i tried starting it. checked the timing and it was off about 8 teeth. EEKK ya!
so a few nights ago i finally got around to fixing the timing back to zero. its on point now. tried starting it and its not making the screetching noise anymore but it wont fire. it cranks but doesnt start. im still getting spark, air and fuel. fuel pump is priming a little louder than it used to as well.
im worried that maybe some damged occured to the head. any ideas? i appreciate any help. thanks!
Old Dec 21, 2005 | 12:10 PM
postman's Avatar
Default Re: please help....motor cranks....doesnt fire (ek99gsr)
bad ckp sensor
Old Dec 21, 2005 | 01:15 PM
hatchi's Avatar
did you put your plug wires on timing correctly?
Old Dec 21, 2005 | 10:36 PM
ek99gsr's Avatar
Default Re: please help....motor cranks....doesnt fire (hatchi)
i put the timing correctly yes. and plug wires...its hard to get wrong as long as you know the 1234 sequence...which i do.
ckp sensor?? what does that stand for and where is it located? or a link of a diagram showing where it is located. thanks guys
Old Dec 21, 2005 | 11:30 PM
SP GARAGE's Avatar
CKP is crank position sensor if i remember correctly
Old Dec 22, 2005 | 10:45 AM
ek99gsr's Avatar
Default Re: (mixxxwell)
bump...anything else?
Old Dec 22, 2005 | 11:41 AM
fmrprojects's Avatar
Default Re: (ek99gsr)
sounds to me like your homie may have gave you back a faulty dizzy. try putting a good one on there
Old Dec 22, 2005 | 02:35 PM
ek99gsr's Avatar
Default Re: (fmrprojects)
ya...thanks for trying and sorry to be a dick but we speak ENGLISH in america. i think you meant D I S T R I B U T O R?? and no its the same one ive had on my car. i swaped them at his house so im sure its my original.
this whole thing doesnt make sense. is it just coinsidence or what? my car ran great up until i swaped the distributor. how could it have jumped 8 teeth....?? i had my water pump and timing belt replaced by a reputable shop about 3-4 weeks before this.
sequence of events:
car ran great, pulled in and parked at his house.
swaped distributors
put same distributor back on when finished.
tried starting my car.....no fire, screetching noise
checked plug sequence, loose connections, pulled injectors to see if they were squirting, etc.
tried starting 3 or 4 more times. no start, same screetch noise when cranking
looked at timing....noticed it was off 8 teeth.
didnt touch anything else
trailored the car home
currently:
set timing back to zero
tried to start.....turns over doesnt fire but no longer makes screetching noise
noticed fuel pump is making a louder unusual noise than it used to.
checked spark, fuel, and air....getting all three
i really dont know what else it could be other than possibly damage to the head
im going to try to put my msd plugs back on tomm and new plugs. i dont know what else it could be. maybe all of that info will help you help me. thanks everyone
Old Dec 23, 2005 | 02:43 PM
ek99gsr's Avatar
bump
Old Dec 24, 2005 | 08:11 AM
ek99gsr's Avatar
BUMMMMMMMPPPP
Old Dec 24, 2005 | 08:17 AM
dohcVTECeg2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek99gsr &raquo;</TD></TR><TR><TD CLASS="quote"> ya...thanks for trying and sorry to be a dick but we speak ENGLISH in america. i think you meant D I S T R I B U T O R??</TD></TR></TABLE>
you were a dick. people wont help you on here if you ask for help and then start crapping on someone cause they said dizzy. either shut up and listen to there help or go out and figure that **** out yourself
Old Dec 24, 2005 | 08:22 AM
redlshatch's Avatar
put the car back in time and then try checking the compression because if you were off 8 teeth and was trying to start the car its possible you bent a valve maybe??? so check the compression in all 4 cylinders e?? thats what i did when my timing jumped a tooth.
Old Dec 24, 2005 | 12:22 PM
puffsef's Avatar
Default Re: (redlshatch)
exactly no help from me dick.
Old Dec 24, 2005 | 06:57 PM
redlshatch's Avatar
Default Re: (puffsef)
what did i do? didnt mean to make anyone mad
Old Dec 25, 2005 | 12:42 AM
ek4shizzle's Avatar
i think you put your spark plugs wrong on the "distributer". its actually a 1342 sequence.
civicsichik
17
Apr 7, 2010 07:44 PM
DACteg
Mar 17, 2010 11:48 AM
civic89si666
Apr 16, 2006 09:50 AM
ludetech
May 20, 2004 10:33 AM
