95 Civic help NOOB
I have a 95 Civic DX. my friend gave me a 2000 Civic EX vtec head and ecu. now i want to put it in my civic and dont know if i need anything else or just plug in the ecu?
Im a newb. so any one pls help me. tell me what else do i need to get to put in this 2000 vtec head and ecu.
all helps appreciated
You'd need to switch to obd2 to use the ecu, so just get a p28 (obd1 ecu) or have you current ecu chipped so that it'll run with the 2000 head. Hope I helped a bit, I'm not big on telling people to search, especially when I search and the archives are full of "search n00b" threads.
Search for mini-me. I bet you'll find roughly 700 threads about this topic. Remember to check archives too. There should be a write-up somewhere about it, tells you all the tools and parts you'll need.
d15b2? Is the car edm? They only put d15b2s in usdm from 88-91, :-(, but you won't be able to use the 2000 ecu, just get a p28 and have it chipped to run the d16y8 maps and you'll be fine.
dont search for da15b2, search under "mini-me" or "mini me". maybe try adding swapping at the end. I did one on my car. But i had a d16. i know that it is really important you remove the oil passage from the block!!!!!! it explains it in the write up, just be sure not to forget. its between cylinder 2 and 3. hope this helps
camp_kill_yourself
Jul 15, 2006 06:36 PM
civc 91
Mar 28, 2005 10:24 AM
He knows everything in the world about them.
