white smoke
Old Dec 21, 2005 | 09:04 AM
1sikhatch's Avatar
Default white smoke
when i get on the gas my car throws out white smoke and doesnt stop until i loose the gas, what causes this smoke?
Old Dec 21, 2005 | 09:06 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: white smoke (1sikhatch)
White smoke is usually coolant burning. See if you can somehow smell it (like a sweet smell)
Or it could be just condensation or w/e from the cold
snatch's Avatar
White is moisture if I remember right. Could be a bad headgasket. Check compression and do a leakdown if you can. Also check your oil to see if there is any coolant mixed in there, it will be milky if there is.
Old Dec 21, 2005 | 09:25 AM
1sikhatch's Avatar
Default Re: white smoke (******)
i checked the compression on 1 and 2 and their at 120-130. i opened my radiator and it looked milky brown. wtf is that from?
Old Dec 21, 2005 | 09:26 AM
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1sikhatch &raquo;</TD></TR><TR><TD CLASS="quote">i checked the compression on 1 and 2 and their at 120-130. i opened my radiator and it looked milky brown. wtf is that from?</TD></TR></TABLE>
You have a blown headgasket most likely
Old Dec 21, 2005 | 09:27 AM
snatch's Avatar
Default Re: white smoke (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1sikhatch &raquo;</TD></TR><TR><TD CLASS="quote"> i opened my radiator and it looked milky brown. wtf is that from?</TD></TR></TABLE>
Blown headgasket.
Old Dec 21, 2005 | 09:41 AM
thresher's Avatar
That is oil in your coolant, which is like the final stages of a blown headgasket. Your motor is toast, I bet when you take off the timing cover the plastic is gonna be melted together from the heat where the head meets the block.
Youre most likely a prime cantidate for a motor swap.
Old Dec 21, 2005 | 09:54 AM
1sikhatch's Avatar
Default Re: white smoke (thresher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thresher &raquo;</TD></TR><TR><TD CLASS="quote">That is oil in your coolant, which is like the final stages of a blown headgasket. Your motor is toast, I bet when you take off the timing cover the plastic is gonna be melted together from the heat where the head meets the block.
Youre most likely a prime cantidate for a motor swap.</TD></TR></TABLE>
actually the plastic is fine, i guess i'll just pull off the head and put a new gasket. the motor was sitting for like 2 years could this be the reason why?
Old Dec 21, 2005 | 10:10 AM
1sikhatch's Avatar
also this is on a z6 motor if that makes any difference. and can i use a hg for a 96-00 civic?
Old Dec 21, 2005 | 10:20 AM
IHateJDM's Avatar
only if he's been driving his car a lot while its overheating. in his situation, i think the worst case scenario would be a warped head.
Old Dec 21, 2005 | 10:30 AM
1sikhatch's Avatar
Default Re: white smoke (IHateJDM)
the car does overheat either, can the head gasket friom a y8 work on the z6?
Old Dec 21, 2005 | 10:33 AM
1993civicex's Avatar
dude just buy a head gasket for the z6 if ur going to buy a y8 head gasket....at least u know the head gasket will keep the same comp ratio changing it could make a diff comp ratio
Old Dec 21, 2005 | 10:37 AM
1sikhatch's Avatar
Default Re: white smoke (1993civicex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993civicex &raquo;</TD></TR><TR><TD CLASS="quote">dude just buy a head gasket for the z6 if ur going to buy a y8 head gasket....at least u know the head gasket will keep the same comp ratio changing it could make a diff comp ratio</TD></TR></TABLE>
reason i asked is because no where around me has the one for the z6, btw with the y8 head gasket will my comp raise or drop?
Old Dec 21, 2005 | 11:10 AM
raise i belive... but if ur really that desperate it will fit it will do its job i was building a z6 with a y8 head and it worked just fine srry bout earlier if i sounded like an ***
Old Dec 21, 2005 | 11:27 AM
StRoKeD-B16bEj2's Avatar
headgasket
Old Dec 21, 2005 | 11:34 AM
1sikhatch's Avatar
Default Re: white smoke (BLaCkMaNEg6)
aight well imma start taking off the head and see whats goin on underneath there, i'll update u guys.
thanks
Old Dec 21, 2005 | 11:56 AM
snatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLaCkMaNEg6 &raquo;</TD></TR><TR><TD CLASS="quote">headgasket</TD></TR></TABLE>
Thanks for the input. You were right on time.
Old Dec 21, 2005 | 01:16 PM
vancoland's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">
only if he's been driving his car a lot while its overheating. in his situation, i think the worst case scenario would be a warped head. </TD></TR></TABLE>
Whats the first sign of a blown headgasket?...and how long would you have to drive with it to get a warped head??
Old Dec 21, 2005 | 01:21 PM
IHateJDM's Avatar
Default Re: white smoke (vancoland)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vancoland &raquo;</TD></TR><TR><TD CLASS="quote">
Whats the first sign of a blown headgasket?...and how long would you have to drive with it to get a warped head??</TD></TR></TABLE>
lots of white smoke from exhaust (burning coolant/water), and temp guage constantly rising. Oil in the coolant is a dead giveaway. As far as warping the head, that all depends on how hot you get it, and how many times you let it get hot and cool off again. If you have a warped head, the motor will still act like the headgasket is blown even if you just installed a new gasket. If that happens, go to a machine shop and have them mill a little off the bottom of the head to level it out and try to find a thicker headgasket to make up for the compression increase you would have with an oem gasket.
Old Dec 21, 2005 | 01:57 PM
vancoland's Avatar
lots of white smoke from exhaust (burning coolant/water), and temp guage constantly rising. Oil in the coolant is a dead giveaway. As far as warping the head, that all depends on how hot you get it, and how many times you let it get hot and cool off again. If you have a warped head, the motor will still act like the headgasket is blown even if you just installed a new gasket. If that happens, go to a machine shop and have them mill a little off the bottom of the head to level it out and try to find a thicker headgasket to make up for the compression increase you would have with an oem gasket. </TD></TR></TABLE>
kewl...its good to know, i don't have a blown hg, but its worriesome to see alot of smoke from the exhaust, but i know theres hella condesation now because of the cold
Old Dec 22, 2005 | 05:25 AM
1sikhatch's Avatar
ok pulled off the head and the gasket looks fine to me here are some pics:
Old Dec 22, 2005 | 06:44 AM
inline4's Avatar
in the middle picture your headgasket is blown. the one all the way to the left, where the metal is showing. there's no more black stuff to keep the coolant from flowing into the combustion chamber.
it was probably a slow leak that's why it never overheated a lot and u never got that much white smoke.
if you get a y8 head gasket for your z6 it will lower the compression, so try to find a z6 headgasket if u want your stock compression.
Old Dec 22, 2005 | 06:49 AM
dohcVTECeg2's Avatar
Default Re: white smoke (inline4)
y8 gasket drops compression
Old Dec 22, 2005 | 06:54 AM
snatch's Avatar
Default Re: white smoke (dohcVTECeg2)
I thought Y8 headgasket raised your compression because it's thinner.
Old Dec 23, 2005 | 04:19 AM
1sikhatch's Avatar
ok i'm still getting smoke it looks blueish white. also i had the valve cover hose to my intake and i noticed my filter is full of oil so i put on a breather filter and eliminate the hose goin to the intake pipe and now the breather is full of oil and their is white smoke coming from the same breather filter.
so whats cause this blueish smoke and oil thing on my filter?
