white smoke
cute little bastard
Re: white smoke (1sikhatch)
White smoke is usually coolant burning. See if you can somehow smell it (like a sweet smell)
Or it could be just condensation or w/e from the cold
White is moisture if I remember right. Could be a bad headgasket. Check compression and do a leakdown if you can. Also check your oil to see if there is any coolant mixed in there, it will be milky if there is.
Re: white smoke (******)
i checked the compression on 1 and 2 and their at 120-130. i opened my radiator and it looked milky brown. wtf is that from?
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1sikhatch »</TD></TR><TR><TD CLASS="quote">i checked the compression on 1 and 2 and their at 120-130. i opened my radiator and it looked milky brown. wtf is that from?</TD></TR></TABLE>
You have a blown headgasket most likely
Re: white smoke (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1sikhatch »</TD></TR><TR><TD CLASS="quote"> i opened my radiator and it looked milky brown. wtf is that from?</TD></TR></TABLE>
Blown headgasket.
Blown headgasket.
That is oil in your coolant, which is like the final stages of a blown headgasket. Your motor is toast, I bet when you take off the timing cover the plastic is gonna be melted together from the heat where the head meets the block.
Youre most likely a prime cantidate for a motor swap.
Re: white smoke (thresher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thresher »</TD></TR><TR><TD CLASS="quote">That is oil in your coolant, which is like the final stages of a blown headgasket. Your motor is toast, I bet when you take off the timing cover the plastic is gonna be melted together from the heat where the head meets the block.
Youre most likely a prime cantidate for a motor swap.</TD></TR></TABLE>
actually the plastic is fine, i guess i'll just pull off the head and put a new gasket. the motor was sitting for like 2 years could this be the reason why?
only if he's been driving his car a lot while its overheating. in his situation, i think the worst case scenario would be a warped head.
dude just buy a head gasket for the z6 if ur going to buy a y8 head gasket....at least u know the head gasket will keep the same comp ratio changing it could make a diff comp ratio
Re: white smoke (1993civicex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993civicex »</TD></TR><TR><TD CLASS="quote">dude just buy a head gasket for the z6 if ur going to buy a y8 head gasket....at least u know the head gasket will keep the same comp ratio changing it could make a diff comp ratio</TD></TR></TABLE>
reason i asked is because no where around me has the one for the z6, btw with the y8 head gasket will my comp raise or drop?
raise i belive... but if ur really that desperate it will fit it will do its job i was building a z6 with a y8 head and it worked just fine srry bout earlier if i sounded like an ***
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLaCkMaNEg6 »</TD></TR><TR><TD CLASS="quote">headgasket</TD></TR></TABLE>
Thanks for the input. You were right on time.
Re: white smoke (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM »</TD></TR><TR><TD CLASS="quote">
only if he's been driving his car a lot while its overheating. in his situation, i think the worst case scenario would be a warped head. </TD></TR></TABLE>
Whats the first sign of a blown headgasket?...and how long would you have to drive with it to get a warped head??
Re: white smoke (vancoland)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vancoland »</TD></TR><TR><TD CLASS="quote">
Whats the first sign of a blown headgasket?...and how long would you have to drive with it to get a warped head??</TD></TR></TABLE>
lots of white smoke from exhaust (burning coolant/water), and temp guage constantly rising. Oil in the coolant is a dead giveaway. As far as warping the head, that all depends on how hot you get it, and how many times you let it get hot and cool off again. If you have a warped head, the motor will still act like the headgasket is blown even if you just installed a new gasket. If that happens, go to a machine shop and have them mill a little off the bottom of the head to level it out and try to find a thicker headgasket to make up for the compression increase you would have with an oem gasket.
lots of white smoke from exhaust (burning coolant/water), and temp guage constantly rising. Oil in the coolant is a dead giveaway. As far as warping the head, that all depends on how hot you get it, and how many times you let it get hot and cool off again. If you have a warped head, the motor will still act like the headgasket is blown even if you just installed a new gasket. If that happens, go to a machine shop and have them mill a little off the bottom of the head to level it out and try to find a thicker headgasket to make up for the compression increase you would have with an oem gasket. </TD></TR></TABLE>
kewl...its good to know, i don't have a blown hg, but its worriesome to see alot of smoke from the exhaust, but i know theres hella condesation now because of the cold
in the middle picture your headgasket is blown. the one all the way to the left, where the metal is showing. there's no more black stuff to keep the coolant from flowing into the combustion chamber.
it was probably a slow leak that's why it never overheated a lot and u never got that much white smoke.
if you get a y8 head gasket for your z6 it will lower the compression, so try to find a z6 headgasket if u want your stock compression.
ok i'm still getting smoke it looks blueish white. also i had the valve cover hose to my intake and i noticed my filter is full of oil so i put on a breather filter and eliminate the hose goin to the intake pipe and now the breather is full of oil and their is white smoke coming from the same breather filter.
so whats cause this blueish smoke and oil thing on my filter?
