lowering the car
Old Mar 17, 2002 | 03:12 PM
Ignitecivic's Avatar
Default lowering the car
wat do i did to do to install the spring. i have all the tools, what do i need to unbolt for the front end. the rear seems easy.
Old Mar 17, 2002 | 03:24 PM
stkd16z6's Avatar
Default Re: lowering the car (Ignitecivic)
on each side unbolt the two top bolts for the strut, on the bottom one bolt on the control arm, and one on the shock fork. if the brake lines are bolted to the strut, unbolt those too. then you should be able to remove the strut/springs assembly out of the car and compress it, or if you dont have a spring compressor, just pop them. i suggest the spring compressor if you've never done this before.
Old Mar 17, 2002 | 03:27 PM
EVIL Hx Coupe's Avatar
Unbolt the two screws on top. Tanl a long one on the bottom. Than Unbolt that little arm around the spring and hit it with a hammer so it drops (gently). After that take the shock and spring out. compress the spring witha spring compressor and then take out the nut on top and do the same thing to put it back. sorry if its not that clear im not so good explaing things I just did this today though. Next time use Search button so u don't get flammed.
Old Mar 17, 2002 | 04:37 PM
Default Re: lowering the car (Boost Pressure)
thanks guys. it helped me alot. imma do it soon during spring break.
masterEF
11
Nov 16, 2010 01:18 PM
niceprelude
13
Feb 26, 2009 09:01 AM
Toolman
Suspension & Brakes
May 2, 2005 06:30 AM
hondaracing1
11
Mar 24, 2005 06:24 PM
crxmadman
Nov 12, 2002 04:33 PM
