Polyurethane Suspension Bushings?
Old Dec 21, 2005 | 08:24 AM
Jesterian's Avatar
Default Polyurethane Suspension Bushings?
Anyone know where I can pick up a full set of polyurethane suspension bushings for my EF? Or if they don't make them, where can I get normal replacements?
Old Dec 21, 2005 | 08:29 AM
dr_latino999's Avatar
Default Re: Polyurethane Suspension Bushings? (Jesterian)
Check out the sponsers forum, I know they will have what you are looking for there.
Old Dec 21, 2005 | 10:54 AM
dravesef's Avatar
or you could try nopi that is where i got mine. it is the prothane kit and comes with all the bushings you will need
Old Dec 26, 2005 | 11:26 AM
aaroboost's Avatar
Default Re: (dravesef)
are these a good investment/mod?
Old Dec 26, 2005 | 11:52 AM
SETI20's Avatar
http://www.summitracing.com
I love mine.
Old Dec 26, 2005 | 03:49 PM
clemsonsi's Avatar
Default Re: (aaro890)
for the money invested, these are possibly the best mod on a car as old as an EF.
however, installation is very labor intensive... so unless you like hours spent working on the car and have a press to remove/install bushings with, get a quote from a decent shop that can handle install for you.
keep in mind, too, that if you don't already have a capable shock/spring or coilover setup, you'll sure want one more after installing urethane bushings
Old Dec 26, 2005 | 05:22 PM
xci_ed6's Avatar
Default Re: (clemsonsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clemsonsi &raquo;</TD></TR><TR><TD CLASS="quote">however, installation is very labor intensive... so unless you like hours spent working on the car and have a press to remove/install bushings with, get a quote from a decent shop that can handle install for you.</TD></TR></TABLE>
werd, total PITA.
You *can* remove the bushings without a press. To do that, clamp the metal center in a vice and twist the control arm around until the center breaks free of the rubber, then pry it out. put a hacksaw blade through the hole, and cut through the rubber and sleeve in two places, about 90* apart. Then use a chisel to pound the sleeve out, starting with the 90* section. Takes 10-15 min. per bushing.
I would recomend a shop. Remove the rear and front LCA's and the front UCA mounts, take them to a shop and have them press them out. Take them home and install the urethane bushings with a vice.
Make sure you have spare bolts around for all 3 rear LCA mounting points, because they are likely to break. Do not install the tie rod or ball joint dust boots, but you may want to replace the tie rods, ball joints, and rear sway bar endlinks at the same time (use the boots that come with the new parts, not the ES boots).
You will also want to pick up the sway bar bushings, since the ES kit does not come with them, autozone's lookup catalog was correct for me, and they arrived at the store in about 3 days.
I am currently doing mine, and also installed the ES TA bushing, traction bars, and EX spindles/brakes. I installed Zerk grease fittings in all bushing locations too (I hate squeaks!).
Old Dec 26, 2005 | 06:51 PM
green91's Avatar
i thought the kit came with new sway bar bushings? im planning on torching my old bushings out..
Old Dec 26, 2005 | 07:25 PM
DelSolDon's Avatar
Default Re: (krustindumm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krustindumm &raquo;</TD></TR><TR><TD CLASS="quote">
werd, total PITA.
same method i used to get my rear LCA bushings out except that i used a torch to burn the rubber out instead of a clamp and elbow grease. just makes some wicked black smoke...f*%k the ozone!
Old Dec 26, 2005 | 09:52 PM
ef nine's Avatar
i got the whole set on old ef(wracked it ) i also got tein ss. i really love it. good and stiff ride
Old Dec 27, 2005 | 09:23 AM
BiG Chris's Avatar
ive got the master kit for my crx also but i havent put it in and ive had the kit for over a year
Old Dec 27, 2005 | 09:27 AM
atc5's Avatar
if anyone needs a set of rear lower control arms bushings for their ef, I have a set. They are ES and are new in the package. $25 shipped. Thanks
Old Dec 27, 2005 | 09:35 AM
SiRay13's Avatar
like stated above the poly urethane bushings are the best bang for your buck on these cars, I have every single bushing on my car poly, it's absolutely awesome, Fortunately i had access to a press when I did mine, but it is possible to take out the old bushings using a vice and some old sockets, the only bushing I had to torch was the trailing arm becuase you need to keep the outer metal shell. I probably spent a week or so doing this so expect your car to be down for awhile. Once you're done you'll really appreciate it.
Old Dec 27, 2005 | 10:54 AM
CRX Toad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SETI20 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.summitracing.com
Jegs also has them
Old Dec 27, 2005 | 11:07 AM
HiProfile's Avatar
Default Re: Polyurethane Suspension Bushings? (CRX Toad)
A buddy of mine also has a full 88-91 civic/crx ES black set since he's changing plans.
The best way is to press them out. The cheapest way is to torch them out, then cut the sleeve at two spots (careful not to cut the arm at all), set the sleeve over a socket the same size, and pound it out.
What I found odd was that after the bushing install it drove straight as an arrow, and the steering wheel was centered too. Beforehand my car pulled a bit to the left, with the wheel pointing a bit left (to go straight).
Old Dec 28, 2005 | 09:30 AM
softail's Avatar
I just did this on my 89crx. This is alot of work. I did it without a press. I used a drill with a small bit and drilled around the inner sleeve enough to remove it with vice grips, than I hack sawed the outer sleeves and knocked them out with a chisel. I ended up going a little into a few of the arms, so be careful if you decide to use this method. Most shops I talked to would not do this work. It was worth it, the car handles and rides much better.
kcari
Suspension & Brakes
Aug 17, 2007 08:52 AM
theputz
14
Feb 5, 2007 03:04 PM
hackish
34
Jul 11, 2006 08:05 PM
litterbox
17
Apr 29, 2005 08:55 AM
Severus
Jul 5, 2003 08:26 PM
