anybody got pics of itr with stock springs and koni yellows?
Old Dec 21, 2005 | 08:06 AM
Black R's Avatar
25 Year Member
Default anybody got pics of itr with stock springs and koni yellows?
are you on the upper or lower perch?
how much is the drop compared to stock shocks?
Old Dec 21, 2005 | 08:33 AM
andyt's Avatar
Default Re: anybody got pics of itr with stock springs and koni yellows? (Black R)
I have that.
I can get a pic tonight, but I'm at work now.
I found on the lower perch that it was just too low and bottomed out alot.
The upper perch is definitely lower than stock, I hate to guess but I would say probably an inch lower?
Old Dec 21, 2005 | 08:48 AM
Black R's Avatar
25 Year Member
Default Re: anybody got pics of itr with stock springs and koni yellows? (andyt)
This is on an itr, right?
I'm asking because on my gf's itr it's super low on the lower perches with stock springs and koni yellows.
But my friend just bought some koni yellows for his itr and it only lowered it a hair on the lower perches.
Old Dec 21, 2005 | 09:08 AM
Alexander's Avatar
When referring to OTS koni yellows...
The rear lower perch sits about half an inch lower than the middle perch which is the "stock" shock equivelant.
The front lower perch sits about an inch and a half lower than the middle perch which is the "stock" shock equivelant.
Old Dec 21, 2005 | 09:09 AM
bender's Avatar
I do. I run at the stock heights (to be autox legal).
When I bought them, the koni website used to said:
Fronts have 2 grooves. Top is stock height, bottom lowers you 30mm.
Rears have 3 grooves. Middle is stock height. Top & bottom are 20mm drop or raise.
Now it says: Adj. spring perch can lower car approx. F & R = 25mm
http://www.koni-na.com/display...tinue
I've got pics (of the car) if that would help.
Old Dec 21, 2005 | 09:11 AM
Eva01's Avatar
I had my GSR on ITR springs and Koni Yellows. From what I remember my Konis had 3 perches and I put it in the middle. I remember it dropped the car about 3/4 of an inch. The lower perch probably would have lowered it another 1/4 inch. However, it doesn't look anywhere close to as dumped as your gf's ITR. I can get a picture if you want.
Old Dec 21, 2005 | 10:15 AM
andyt's Avatar
Yep, on an ITR.
Mine has 2 perches front, 1 rear.
Koni told me on the phone that the upper perch in the front should be stock height.
But it most definitely is not. 1.5 inches might be about right, as someone else indicated.
Like you experienced, the lower perch is awfully low...
There must be at least 3 different yellows that have been used on ITRs based on the responses!
Time to start comparing part #s...
Old Dec 21, 2005 | 10:37 AM
zc911's Avatar
i do give me a sec to find the pics
Old Dec 21, 2005 | 10:45 AM
zc911's Avatar
My yellows have 3 grooves in the front shock, this is on the middle. My instructions said the top grove raised the car, the bottom goove lowered the car, and middle was stock
Old Dec 21, 2005 | 11:13 AM
KraZyCHOWMEIN's Avatar
Default Re: anybody got pics of itr with stock springs and koni yellows? (zc911)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zc911 &raquo;</TD></TR><TR><TD CLASS="quote">My yellows have 3 grooves in the front shock, this is on the middle. My instructions said the top grove raised the car, the bottom goove lowered the car, and middle was stock
looks like stock height...
Old Dec 21, 2005 | 12:18 PM
andyt's Avatar
Old Dec 21, 2005 | 03:08 PM
Not bad, is that on the lowest perch?
Old Dec 21, 2005 | 03:11 PM
andyt's Avatar
Default Re: anybody got pics of itr with stock springs and koni yellows? (KraZyCHOWMEIN)
Negative, thats on the upper perch.
The lower perch, as you can see, um, was a little ... close.
Old Dec 21, 2005 | 06:42 PM
AntonioH's Avatar
Ken I'll have to drive out tomorrow night to show you what I'm yapping about. I have both on the lower perches w/ the stock springs. It's still not as dumped as Amy's.
Old Dec 21, 2005 | 07:21 PM
andyt's Avatar
Default Re: (AntonioH)
Forgot this earlier, my part numbers are
Front: 8041 1152 Sport
Rear: 8040 1078 Sport
Old Dec 21, 2005 | 08:36 PM
92TypeR's Avatar
FSAE
Default Re: (andyt)
Stock springs, revalved koni yellows, lower perch.
Old Dec 22, 2005 | 06:36 AM
.RJ's Avatar
.RJ
bL1ng!!!
Install thread - https://honda-tech.com/zerothread?id=1106020
postwhore pics -
Old Dec 22, 2005 | 06:41 AM
Chris F's Avatar
http://www.we-todd-did-racing....D.jpg
ac_attak
Oct 26, 2006 07:01 PM
Jlamar757
Suspension & Brakes
Apr 21, 2006 12:19 AM
t_c_l_6
Suspension & Brakes
Mar 19, 2006 05:29 PM
cmdr430
Honda S2000
10
Apr 17, 2005 11:05 PM
edoyboy
Dec 26, 2004 09:45 AM
