Suspension & Brakes Theory, alignment, spring rates....
94 hatch w/tokico blues--whats the allen/nut at the top??
Old Dec 21, 2005 | 06:32 AM
Ratchback's Avatar
Default 94 hatch w/tokico blues--whats the allen/nut at the top??
Hey there i was wondering which way i would have to turn the allen key while i hold the nut to tighten and which way to loosen or if this even works. I know on the illuminas they have the 5 way adjustable on the top, mine looks the same but it's just the turn of an allen key instead, i know it adjusts it somehow but im looking for a stiffer type of ride. Im getting a lot of body roll when i take turns. I have the tokico blues with eibach sportlines 1.5" springs. thanks
aaron
Old Dec 21, 2005 | 07:28 PM
94hatchling's Avatar
Default Re: 94 hatch w/tokico blues--whats the allen/nut at the top?? (Ratchback)
tokico blues are non-adjustable. they are a stock replacement.
the allen key at the top is used to aid in loosening the nut. in most cases the shaft spins with the nut, you put in the corresponding allen wrench, and you can then remove nut.
dc5itracer
Oct 2, 2008 06:19 PM
PinoyDelSol
Suspension & Brakes
13
Feb 1, 2008 10:24 AM
vinuneuro
Suspension & Brakes
Mar 4, 2007 12:02 PM
AzntaggeR
Feb 12, 2004 12:19 PM
