clock & cd player problems!! Need help!!
Old Dec 21, 2005 | 04:32 AM
all_motor's Avatar
Default clock & cd player problems!! Need help!!
My clock and cd player always resets whenever I turn the engine off. I have to reprogram everything. It sucks. Anyways, I checked all the fuses, engine and under dash, the fuses are still good. I am out of ideas. Help!!!!
Old Dec 21, 2005 | 04:53 AM
VegaS10's Avatar
Default Re: clock & cd player problems!! Need help!! (all_motor)
Is the clock using factory wiring, or did you go in and rewire it? Same with the cd player...stock wiring?
Old Dec 21, 2005 | 09:41 PM
all_motor's Avatar
Default Re: clock & cd player problems!! Need help!! (VegaS10)
Everything is stock. The only thing I did was I bought an aftermarket harness for the new cd player that I hooked up. None of the factory wires were cut/spliced.
Old Dec 21, 2005 | 09:44 PM
Pee Wee's Avatar
swap the 2 power wires around
Old Dec 21, 2005 | 09:56 PM
all_motor's Avatar
Default Re: clock & cd player problems!! Need help!! (EF8opey)
mmm...which power wires are you talking about??
Old Dec 21, 2005 | 09:57 PM
Jonathan_ED3's Avatar
12v constant and 12v switched
Old Dec 21, 2005 | 10:21 PM
all_motor's Avatar
Default Re: (Jonathan_ED3)
Do I switch the two power wires from the clock or radio? Or does it matter?
Old Dec 22, 2005 | 01:49 AM
VegaS10's Avatar
You're saying the clock does'nt hold memory? Odd.
The factory 12 volt CONSTANT wire is white and blue. Make sure that the memory/constant wire on your new radio (usually yellow) is hooked to this wire.
Old Dec 22, 2005 | 02:14 AM
all_motor's Avatar
Default Re: (VegaS10)
Yes both the clock and cd player doesnt hold memory. It's been like this even before I installed the aftermarket cd player.
Old Dec 22, 2005 | 06:43 AM
crx_88_si's Avatar
Default Re: (all_motor)
the factory clock? wierd. The car starts fine?
Double check ALL radio fuses w/ a continuity test on a voltmeter. maybe one is burnt and u can't see it?
Old Dec 22, 2005 | 08:41 AM
I had a problem a while back with a fuse.
The clock and radio would both work, but they wouldn't hold memory.
Turns out a fuse was burned out and I overlooked for about a month straight while trying to diagnose the problem
Old Dec 22, 2005 | 10:12 PM
all_motor's Avatar
Yes its the factory clock and the car starts fine. I'll recheck all the fuses, but I doubt it because I've checked it 3 times already. I will also try with a voltmeter. Which fuse was it? Was it the one under the dash(drivers side) or under the hood (engine compartment)?
Old Dec 23, 2005 | 04:31 AM
VegaS10's Avatar
Pull each fuse out and inspect it. It should take no more than 2 minutes to check all of them with this method.
You'd be surprised as to what each fuse ties into. In alot of cases the interior light fuse (dome light), is tied into the radio memory fuse as well, etc...
si_23
Apr 10, 2011 01:56 PM
EGgarniEG
May 30, 2007 02:02 PM
Steezn4NOReason
Nov 23, 2004 11:28 PM
integlude
Nov 14, 2004 07:13 PM
North_Texas
Audio / Security / Video
Jun 7, 2004 10:38 AM
