brake light stays on
Old Dec 20, 2005 | 10:55 PM
kyle5486's Avatar
Default brake light stays on
i have a 5th gen prelude and recently i noticed that the brake light turns on and stays on randomnly....its not all the time but its just annoying...i try to just push the e-brake as far down as possible but that doesnt even work...any suggestions would be appreciated...thanks
Old Dec 20, 2005 | 10:58 PM
Hawkze_2.3's Avatar
Default Re: brake light stays on (kyle5486)
Just get in there and adjust the switch for the brake light on your e-brake...then if that doesn't fix it you may have a problem.
Old Dec 20, 2005 | 11:34 PM
SnlpeR's Avatar
brake fluid
Old Dec 21, 2005 | 12:00 AM
onefastrx7turbo's Avatar
Default Re: (SnlpeR)
Old Dec 21, 2005 | 10:12 PM
wheatyaaron's Avatar
i've seen the float switch on the brake fluid tank cause that because it was going bad and because you are low on brake fluid. i've also seen an e-brake so out of adjustment and with a frozen cable that kept the lever from returning all the way down. both pretty easy to fix.
shocker911
Oct 7, 2010 04:24 PM
hatch96y7
Oct 26, 2007 08:08 AM
lmattera
Feb 6, 2006 10:46 AM
3 plus 1
Dec 2, 2003 07:42 AM
SlowazzGSR
Jun 7, 2002 10:30 PM
