HID retrofiting
Old Dec 20, 2005 | 07:26 PM
futurefastguy's Avatar
Default HID retrofiting
a friend of mines is offering me a sweet deal on some projectors from a tsx. my question is, has anybody messed with them in a eg housing? anybody have any experiance retrofitting with the tsx projectors?
Old Dec 20, 2005 | 07:35 PM
Mr. JDM-GSR's Avatar
Default Re: HID retrofiting (futurefastguy)
CHECK WITH JDMLIFESTYLE ON HERE.(sorry bout the caps)
he does retrofitting
Old Dec 20, 2005 | 07:38 PM
98_4drCivic's Avatar
im curious as well. i know that it is possible, but i dont know how easy it is to do. your stock housings wont scatter the light properly and it wont light evenly.
Old Dec 20, 2005 | 07:48 PM
fastrunner's Avatar
Default Re: (98_4drCivic)
you cant or shouldnt use OEM headlights for HID retrofit, the lenses are fluted/fresnel. the lines you see on the inside of the lense will distort light. get some aftermarket projector headlights for HID retrofit.
Old Dec 20, 2005 | 07:53 PM
JDMlyfestyle's Avatar
Yes i have done it and they are great projectors. but they can be difficult to work with because the cutoff is soo touchy it has to be aligned perfectly.
Old Dec 21, 2005 | 04:12 PM
Default Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastrunner &raquo;</TD></TR><TR><TD CLASS="quote">you cant or shouldnt use OEM headlights for HID retrofit, the lenses are fluted/fresnel. the lines you see on the inside of the lense will distort light. get some aftermarket projector headlights for HID retrofit.</TD></TR></TABLE>
like wich ones. hopefully it isn't one of them ricey looking one from egay.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">Yes i have done it and they are great projectors. but they can be difficult to work with because the cutoff is soo touchy it has to be aligned perfectly.</TD></TR></TABLE>
you have any pics of the tsx projectors in action?
Old Dec 21, 2005 | 04:21 PM
Default Re: (futurefastguy)
These are not my pictures!!!!!!
But here is TSX's in action
Old Dec 21, 2005 | 04:30 PM
pure sex
Old Dec 21, 2005 | 04:33 PM
Civic4less's Avatar
Thats HOT! JDMlyfestyle... you da maannnn.
There's an HID thread around here somewhere. Look for it its great. It's on my favorites on AOL but not on what i'm using right now.. erm..
Old Dec 21, 2005 | 04:47 PM
revvin9k's Avatar
They look exactly like the S2000 cutoffs, very nice indeed.
Old Dec 21, 2005 | 05:22 PM
skrewdriver88's Avatar
Default Re: (revvin9k)
nice
Old Dec 21, 2005 | 06:00 PM
Caveman74's Avatar
Default Re: (skrewdriver88)
I have TSX in my TYC one piece. Best lights for the price.
Old Dec 21, 2005 | 06:08 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: (Caveman74)
Just to let you know.. you can use your stock lights.. The fluted lenses will cause the cutoff to not be as crisp as non-fluted lenses, but it wont make them blind everyone or anything.
And you can use any projectors with non-fluted, clear glass/plastic.
Old Dec 21, 2005 | 06:16 PM
dohcVTECeg2's Avatar
Default Re: (Hatchy-Ownzjo0)
tsx hid is pure sex
Old Dec 21, 2005 | 06:24 PM
Hulk_EJ8's Avatar
That's a great job.
[/QUOTE]
Old Dec 21, 2005 | 06:35 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: (Hulk_EJ8)
looks great
Old Dec 21, 2005 | 07:10 PM
jdm123's Avatar
tsx hids= teh hotness
Old Dec 21, 2005 | 07:17 PM
civicliveit's Avatar
Default Re: (jdm123)
i actually am in the middle of my hid retrofit of some mercedes bi xenon hids in my denji projectors. and im having an issue with the mounting of the projectors in the housing. other than that, i havent ran into any issue
Old Dec 21, 2005 | 08:14 PM
SuperSlow's Avatar
you can consider finding -bionic- on here. or go to http://www.customlightz.com. Some of the best out there, and very well worth waiting for.
Old Dec 21, 2005 | 08:30 PM
FalkenSiR's Avatar
Default Re: HID retrofiting (SuperSlow)
beautiful
Old Dec 21, 2005 | 09:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow &raquo;</TD></TR><TR><TD CLASS="quote">you can consider finding -bionic- on here. or go to http://www.customlightz.com. Some of the best out there, and very well worth waiting for. </TD></TR></TABLE>
I havent seen his work personally.. but $250+ for labor and you still have other options as to painting the housings ECT.
I charge MAX is $200 and that is for Housings that i havent messed with yet.
Most Retrofits i are $150 labor and that includes paint, Shouds and Trimming.
Old Dec 21, 2005 | 09:44 PM
t0ekn3e's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchy-Ownzjo0 &raquo;</TD></TR><TR><TD CLASS="quote">Just to let you know.. you can use your stock lights.. The fluted lenses will cause the cutoff to not be as crisp as non-fluted lenses, but it wont make them blind everyone or anything.
And you can use any projectors with non-fluted, clear glass/plastic.</TD></TR></TABLE>
so the stock fluted lenses wont affect the cut-off at all?
Old Dec 21, 2005 | 09:55 PM
H-T Poker champion
Default Re: (t0ekn3e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0ekn3e &raquo;</TD></TR><TR><TD CLASS="quote">so the stock fluted lenses wont affect the cut-off at all?</TD></TR></TABLE>
No.. I did not say that at all. Yes, it will affect the cut-off, and it will make the light out-put worse than with non-fluted lenses. However, this will still be 500 times better than the stock lighting.
Non-Fluted is the way to go, if you can. However, it is not something you HAVE to do. Any retrofit done correctly will have amazing results regardless of fluted or non-fluted lenses, but non-fluted lenses are preferred and all around better to use.
Old Dec 21, 2005 | 10:10 PM
t0ekn3e's Avatar
sorry i misread, finished with finals 2 weeks ago, brain got shut off.
Old Dec 21, 2005 | 11:58 PM
JRizEJ6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hulk_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>[/QUOTE]
ummm...srt-4?
