which distibutor??
Old Dec 20, 2005 | 07:25 PM
Phrost's Avatar
Default which distibutor??
88 civic hatch dx with d16z6 head which distibutor do i use if i use the one off the d16z6 engine do i have to modify the harness or plug?? please help
Old Dec 20, 2005 | 07:27 PM
Mach69's Avatar
Default Re: which distibutor?? (Phrost)
You use the z6 distributor. I believed its TD-42U. Not 100% on that. And you will want to convert to mpfi and obd-1 with a p28 ecu. You will have to modify the distributor plug and engine harness.
Old Dec 20, 2005 | 07:31 PM
Phrost's Avatar
Default Re: which distibutor?? (Mach69)
ok now if i use the origional distributor will it work if i drill the top hole on the disributor and use only one bolt to hold it just tighten the **** out of it i just need this to work for a little while like for 2 months or so?
the reason why im asking if i could do that instead is cause we are on a budget and already bought the head timing pulley and timing belt (which also didnt fit) so we are just about out of cash
Old Dec 20, 2005 | 07:32 PM
si0385.'s Avatar
rywire.com makes the harness adapter that you need
Old Dec 20, 2005 | 07:42 PM
mr. carpenter's Avatar
https://honda-tech.com/zerothread?id=913151
Old Dec 20, 2005 | 11:03 PM
Phrost's Avatar
i also need to know which timing belt am i going to need since i bought the wrong one i got the one for the 88 civicdx to big though so now which one??
Old Dec 20, 2005 | 11:47 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phrost &raquo;</TD></TR><TR><TD CLASS="quote">i also need to know which timing belt am i going to need since i bought the wrong one i got the one for the 88 civicdx to big though so now which one??</TD></TR></TABLE>
Use the D16z6 belt..
Old Dec 21, 2005 | 05:35 AM
Phrost's Avatar
Default Re: which distibutor?? (Mr.speaker)
will the 92-95 civic non vtec belt work
Modified by Phrost at 8:51 AM 12/21/2005
Old Dec 21, 2005 | 05:43 AM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phrost &raquo;</TD></TR><TR><TD CLASS="quote">will the 9-95 civic non vtec belt work
It's to long..
And actually don't get the d16z6 timing belt,get the d16y8..It's same as the d16z6 but alot cheaper..
Old Dec 21, 2005 | 09:02 PM
Phrost's Avatar
today i bought the y8 timing belt and the teeth are to close together so the belt doesnt even go on at all
dragva5g
Oct 28, 2011 07:03 AM
Vtec Civic 93
10
Aug 13, 2010 12:12 AM
kgard
Nov 5, 2005 12:40 AM
GSR-Civic
May 28, 2004 10:43 PM
Sirex
Mar 18, 2003 07:31 PM
