short ram intake install
Old Dec 20, 2005 | 07:20 PM
sony224422's Avatar
Default short ram intake install
Do i need a bypass valve for one of these? I live in CT and it does rain and there are huge puddles sometimes around here. I don't wanna suck water in.. but i don't want a full cai. I like the ebay style short rams.. will these suck water in?
Old Dec 20, 2005 | 07:27 PM
The_Todd's Avatar
Farts in the shower
Default Re: short ram intake install (sony224422)
Short ram, no.
Old Dec 20, 2005 | 07:43 PM
gianinline's Avatar
No.... the rain itself won't do nothing to it....
If you try go through a flooded road... and the water is as high as your hood... then that would be a different story!
Short ram will work fine for you dawg....
Old Dec 21, 2005 | 03:23 AM
sony224422's Avatar
Default Re: short ram intake install (gianinline)
can the stock intake suck in water if you go through a puddle up to the hood? Cus i have gone through puddles up to my headlights before on a flooded road.
Old Dec 21, 2005 | 03:28 AM
The_Todd's Avatar
Farts in the shower
Well you probably shouldn't do that but the stock airbox is semi-sealed and a small jug at the bottom and it uses rubber seals so it should be water tight to a point.
Old Dec 21, 2005 | 03:38 AM
sony224422's Avatar
Default Re: short ram intake install (.ken)
yeah i've only done it once by accident, i didn't realize it was going to be so deep. but i'll be fine with a short ram with no by pass?
Old Dec 21, 2005 | 03:53 AM
TouringAccord's Avatar
H-T Order of Merit
yes, as long as you stay off those floaded roads.
Old Dec 21, 2005 | 12:39 PM
sony224422's Avatar
Default Re: short ram intake install (TouringAccord)
what happens if water is sucked into the engine. I know its hydrolocked but what does that mean
Old Dec 21, 2005 | 12:45 PM
sony224422's Avatar
and is there a bypass for short ram?
Old Dec 21, 2005 | 12:46 PM
1993civicex's Avatar
means u fucked up....jk usally means ur pistons stop instantly but crank keeps moving and u got ur self a rod wrapped around a crankshaft
Old Dec 21, 2005 | 12:54 PM
sony224422's Avatar
Default Re: short ram intake install (1993civicex)
ew doesn't sound fun.
Is there a bypass for short ram?
Old Dec 21, 2005 | 01:06 PM
philadd's Avatar
No, there's no bypass for a short ram. It wouldn't do any good. If you had a bypass, it would allow air to sucked in through there instead of the filter, and on a short ram that's about the same height.
In any case, even with a stock airbox it's recommended that you do not drive in water that's higher than the curb, and especially not in water that's up to the door sills. Any more than that and you're asking for trouble.
As far as what hydrolock means... Well, put it this way: Normally the motor is compressing air, right? Now fill the cylinders with water. Water doesn't compress. The engine tries to compress the water, so something has to give, and it's not going to be the water.
Many people are lucky enough not to suffer any engine damage, but do you really want to chance it? Just don't drive through flooded streets.
Old Dec 21, 2005 | 01:44 PM
Default Re: short ram intake install (philadd)
usally the rods its a bitch..i have a short ram on my civic its all good u dont have to worry about water the intake is right at the lvl of the stock airbox but in rainy season keep ur stock airbox its like a 5 min job going back and forth...here in sunny cali i sold my stock air box lol
Old Dec 21, 2005 | 01:52 PM
zumiez007's Avatar
water would get in the exhaust and stall the engine that way before water will hydrolock the engine.
Old Dec 21, 2005 | 03:31 PM
sony224422's Avatar
Default Re: short ram intake install (zumiez007)
i've hit water up to my headlights before. But yeah your right, my car sputtered and didn't like it all. But i guess i'll get a short ram even though they don't do anything but make the car look not stock i guess haha. Does CAI have more effect than a short ram?
Old Dec 21, 2005 | 03:43 PM
slightly
Pr0j3ctxH@tchx90
May 20, 2007 06:23 PM
egzo04
Sep 8, 2005 10:22 AM
gnuel
May 27, 2004 05:46 AM
civicboy95
Sep 12, 2002 12:58 PM
94LSTEG
Sep 20, 2001 12:44 PM
