How to restart the check engine light in 91 accord
It's the 7.5amp (radio backup) fuse in the under hood fuse box. Leave it out for 10 seconds, and put it back in. You may have to redu the radio presets afterwards.
Modified by BLKFLSH at 10:41 PM 12/21/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hennessy »</TD></TR><TR><TD CLASS="quote">wait a minute, what do you mean the security system? Is that if i have an alarm?</TD></TR></TABLE>
Stock radio code.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hennessy »</TD></TR><TR><TD CLASS="quote">I need to know how to reset the check engine light so that i could take this car for my licensing test.... does anybody know how to reset it?</TD></TR></TABLE>
But won't it come back on through the test?
Fix the problem, don't band-aid problems, it'll bite you in the *** later.
Stock radio code.
yeah i want to fix the problem if i could, but i dont want to take it to a shop because they over charge...is there any way i can find out whats wrong on my own? Tips and tricks?
do not woory about the alarm even if you do have one , it is non-factory,, removing that fuse should not affect it ... also if you don't have an anti-theft radio do not worry about it ... what BLK says is correct to reset computer ,about the fuse etc etc,,,
Just pull the 7.5amp fuse in under hood fuse box (for 10 seconds) it will clear the code. Of course it (the light) will come back, sooner or later. What you need to do is go to Autozone and get them to check the codes for you (I think they do it for free). Then come back and post codes.
Modified by BLKFLSH at 10:42 PM 12/21/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hennessy »</TD></TR><TR><TD CLASS="quote">yeah i want to fix the problem if i could, but i dont want to take it to a shop because they over charge...is there any way i can find out whats wrong on my own? Tips and tricks?</TD></TR></TABLE>
Take the whip to Autozone they will let you scan your comp for free if any codes are on (check engine light on) and ask them what the codes mean.
you need to read the code and post it here ...someone will help you diagnose it ......there is a blue 2 wire plug under the right side dash ( kick panel),, plug might be taped with blue tape,, jump those 2 wires together. put key on position ,lite will blink on instrument cluster........a series of short and or long blinks,, a long blink is equal to 10 a short one to 1 ,, so 2 long 1 short would be 21 and so on...read and pot it ..
Go to the passenger side of your car and lift up the carpet and there should be a window with a light flashing, longs are 10's and shorts are singles so long long long short would be code 31. Find the code and post it here.
Also, there should be a jumper cable that you can jump and the cel on your dash should flash the same amount. Obviously you'll have to have the car trip the cel to get the cel.
edit: deserthonda beat me to it
your car will not hook up to a parts store scan tool , you'll need to jumper the blue 2 pin connector and turn on the key to get the flash code Link Below
http://members.troublecodes.ne...n.jpg
Go to auto zone and they will run a diagnosis on it for free to tell you what the code is that it threw and mayb some free advice on how to fix the problem. Which hopefully it isnt major. Anyways good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .ken »</TD></TR><TR><TD CLASS="quote">Go to the passenger side of your car and lift up the carpet and there should be a window with a light flashing, longs are 10's and shorts are singles so long long long short would be code 31. Find the code and post it here.
i dont think any 91 accords have that light on the ecu, as far as i konw that was only on the obd0 ecus. 91s are obd1
</TD></TR></TABLE>i dont think any 91 accords have that light on the ecu, as far as i konw that was only on the obd0 ecus. 91s are obd1
On my 90 it had an opening for the ecu and I thought 90-91 were the same in regards to ecu...never really looked into it that much but I knew my 90 had it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hennessy »</TD></TR><TR><TD CLASS="quote">what about schucks?, will they give a free diagnosis? this is the only parts store that is close to my house...</TD></TR></TABLE>
u can chk it urself it is really easy to do,, just find that plug get a paper clip and jump the 2 wires together ,,put key on and read the blinks ,,let it repeat a few times just in case there might be more than 1 code stored ..
Autozone can't do the diagnostic because your car is not OBD2. 96 and newer only. For you, there is a little blue connector under the dash on the right side. It will either be under the dash, or under the right side kick panel. You stick a paper clip and connect it to both sides of the wire, then turn the car to the on position. Your check engine light will blink, and that code determines what the check engine light is about.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrichards2005 »</TD></TR><TR><TD CLASS="quote">Autozone can't do the diagnostic because your car is not OBD2. 96 and newer only. For you, there is a little blue connector under the dash on the right side. It will either be under the dash, or under the right side kick panel. You stick a paper clip and connect it to both sides of the wire, then turn the car to the on position. Your check engine light will blink, and that code determines what the check engine light is about.</TD></TR></TABLE>
Hey man thanks for correcting me it makes since, I took my 00' jeep instead of the accord. I didnt know appreciate it.
It is probably that plug with the orange and green wires going to it. Take a paper clip (or wire) whatever and connect the two wires together. When you turn the key on, the check engine light will blink the code. Let it blink the code a few times, to make sure you get them right. Long blinks are for the ten position. Short blinks are for the one position. Example: Three long blinks, then two short blinks. This would be code 32 get it. (It may blink more than one code) When you have fixed the problem, you can take the 7.5amp fuse out of the fuse box (under hood). Keep it out for 10 seconds, then put it back in. The computer will be reset, and if you have the stock radio, you will have to reprogram the presets for your favorite stations. BLUE PLUG WITH TWO WIRES, ORANGE AND GREEN.
Modified by BLKFLSH at 11:09 PM 12/21/2005
Is this picture taken near the kick panel? Towards the front of the passenger side door?
Modified by BLKFLSH at 11:10 PM 12/21/2005
