need timing belt info
Old Dec 20, 2005 | 04:54 PM
Keri's_baby's Avatar
Default need timing belt info
Need diagram on how timing belt and belt tensionor is installed on a d16A6 si motor. Dont wont to mess up when i put it on.
Old Dec 20, 2005 | 06:21 PM
CRXb18Turbo's Avatar
Default Re: need timing belt info (Keri's_baby)
just the same way as you remove it.
Just make sure all your marking and timming are line up.
Old Dec 20, 2005 | 07:44 PM
mr. carpenter's Avatar
Default Re: need timing belt info (CRXb18Turbo)
buy a twenty dollar haynes manual. it has an excellent step by step.
Old Dec 20, 2005 | 09:28 PM
SD_Lurker's Avatar
HT White Ops
Put the motor to TDC then take off the belt. reapply the belt and make sure that you are still at TDC. Turn the motor a full rotation and amke sure you are at TDC after the full rotation. If everything is ok then reassemble. I know its brief but I hope it helps. Good Luck
Old Dec 20, 2005 | 09:29 PM
SD_Lurker's Avatar
HT White Ops
Default Re: need timing belt info (nicks_jdmstyle_ef9)
TDC= top dead center
Old Dec 20, 2005 | 10:47 PM
jacoop86's Avatar
i found a good writeup here:
http://www.c-speedracing.com/h...t.php
its for a b18 but i would think its simalar
Old Dec 21, 2005 | 01:19 PM
thanks for the info installation pretty easy uh.
slide inside
Oct 22, 2009 09:25 AM
huge230
Oct 4, 2005 12:31 PM
Ziggymidget5
Apr 20, 2005 03:23 PM
johnzm
Jun 16, 2002 06:56 PM
KoRE
Jun 15, 2002 09:27 AM
