h22 stroker motor
it'll work fine, you might need to bend or remove the oil squirters for clearance. The F22 rods/crank are the same as the H23 ones. Also this would have to be in a pre 98 block as 98 and above have 55 mm mains while the F22/H23 has 50 mm mains.
yeah i know but i would like to have some reading material befor i junp in to far as i thought about picking up a set of type s pistons to go with the combo as well
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Rex »</TD></TR><TR><TD CLASS="quote">yeah i know but i would like to have some reading material befor i junp in to far as i thought about picking up a set of type s pistons to go with the combo as well</TD></TR></TABLE>
what other info do you need?
type s pistons will stick out of the hole a bit and have a lot of compression...
btw: did you see this thread...because there is a H23A/H22A thread in there.
https://honda-tech.com/zerothread?id=689805
Check out this thread. https://honda-tech.com/zerothread?id=1399259
jdm knight
Feb 22, 2006 01:00 PM
