Just got my car back from alignment.. -tech questions
Old Mar 17, 2002 | 01:06 PM
BluLuder's Avatar
Default Just got my car back from alignment.. -tech questions
Got some crazy readings. I have Sportlines and Eibach Blues on all 4 corners for about 2 years. It says my Caster on the right side is set waay back. And my camber on the rear passenger side is -2 degrees while the other side is pretty much normal. What would cause these things?
How do I fix the Caster on the front? (Its a 4gen Prelude Si)
Old Mar 18, 2002 | 05:45 PM
BluLuder's Avatar
Default Re: Just got my car back from alignment.. -tech questions (BluLuder)
ttt
Old Mar 18, 2002 | 06:19 PM
DR. ON POINT's Avatar
Banned
just the wear and tear of a car...hittin bumps in the road...**** like that....I use to do alignments every once and a while...by the way ur nubers arent that bad
Old Mar 18, 2002 | 06:48 PM
fixhondas's Avatar
You can fix caster by either repairing anything that is bent or by shimmingor bending the radius rod or by having it pulled by a frame shop or by installing adjustable upper control arm balljoints with this capability. The rear camber can be shimmed more positive with washers or shims.
Old Mar 19, 2002 | 05:37 AM
BluLuder's Avatar
Default Re: Just got my car back from alignment.. -tech questions (fixhondas)
Yeah Ill hafta see if my front strut is bent on that side.. Thanks for the info guys.
Im gonna attempt to add washers to the rear. What side washers and wear exactly do I add them?
Old Mar 19, 2002 | 05:47 AM
Banned
for the rear camberadd them between ur upper control arm and the car
Old Mar 19, 2002 | 05:58 AM
BluLuder's Avatar
Default Re: Just got my car back from alignment.. -tech questions (On Point EK)
Ok, what size washers about? like 14mm? thanks again.
Old Mar 19, 2002 | 07:25 AM
rainforest's Avatar
any size bigger r=than the bolt will work(oviouslly dont go to like a22mm washer)
yeah hondas suck no castor or camber adjustment.
wannaBjdmca6
Suspension & Brakes
29
Jan 22, 2011 08:52 AM
wannaBjdmca6
Suspension & Brakes
26
Jan 16, 2011 08:24 PM
tsar
Honda S2000
Apr 3, 2010 09:22 AM
beana
Jan 4, 2010 02:08 PM
StolenTeg
Jul 2, 2006 11:26 PM
