can i use a crv timing belt on my lsvtec swap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racingant »</TD></TR><TR><TD CLASS="quote">if i use a ls water pump and a b16 oil pump i can use the crv timing belt right</TD></TR></TABLE>
Yup..
It has nothing to do with what oil pump you use by the way,It's all about which water pump you use,,If you use the 22 tooth waterpump get a VTEC timing belt,,19 tooth get a NON-vtec belt..
In my opinion the 22 tooth waterpump would be better beacuse at high rpm it wouldn't be spinning as fast as the 19 tooth waterpump
Modified by Mr.speaker at 12:13 PM 12/22/2005
Yup..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">
Yup..
It has nothing to do with what oil pump by the way,It's all about which water pump you use,,If you use the 22 tooth waterpump get a VTEC timing belt,,19 tooth get a NON-vtec waterpump..
exactly, if you want to build a reliable high rpm ls/v, i would recommend all vtec components, of course oil pump, but water pump(22 tooth) and timing belt (either gsr/type-r) just my two pennies
Yup..
