Greddy Profec Type S boost controller problem
At first it would not regulate at all and it kept building up boost up to like 21 psi. Well we found out the DRAG kit wastegate is a dual port setup so we ran two lines from the solenoid into the top of the wastegate and on the side.
Well at the lowest setting it boosts till 14psi. Im supposed to see 7psi from the wastegate. Anyone else have this problem? Maybe its operator error and im not tuning it right. GAIN set to min and LO BOOST set to min. Never had this problem with my manual boost controller but it broke.
then hook the two that you're gonna use
