turbo + ecu codes = ???
Old Dec 20, 2005 | 10:18 AM
zxc4's Avatar
Default turbo + ecu codes = ???
i just converted to obd1 in my 89 crx si with a b16a1, i am now throwing a code 9 (tdc/crank/cyl sensor), code 14 (iacv), and a code 20 (eld). How bad of an idea is it to run a turbo kit when I am throwing ecu codes? the car seems to be running fine.
Old Dec 20, 2005 | 10:32 AM
beyondspexj's Avatar
common sense would be to fix the cel's before boosting the motor. just check your wiring since you converted the obd system
Old Dec 20, 2005 | 10:37 AM
zxc4's Avatar
ive been trying to fix them for a few days now. Just wondering if it comes down to it, how bad is it to run boost with ecu codes, these in particular
Old Dec 20, 2005 | 10:43 AM
Autoworks's Avatar
Default Re: (beyondspecs_jamar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beyondspecs_jamar &raquo;</TD></TR><TR><TD CLASS="quote">common sense would be to fix the cel's before boosting the motor. just check your wiring since you converted the obd system</TD></TR></TABLE>
SEARCH AND FIND HOW TO CORRECT THE CODES (caps lock)
Old Dec 20, 2005 | 10:44 AM
md88hfcrx's Avatar
Default Re: (Autoworks)
definately dont run boost on an unhealthy engine
Old Dec 20, 2005 | 10:45 AM
zxc4's Avatar
i know
https://honda-tech.com/zerothread?id=468260
no such luck yet. someone please answer the question thanks
Old Dec 20, 2005 | 10:47 AM
zxc4's Avatar
i think its probably a bad dizzy for the code 9 and 20, and bad wiring for the iacv. if it seems to be running good do codes necessarily make it "unhealthy" ?
Old Dec 20, 2005 | 11:26 AM
technine's Avatar
Default Re: (zxc4)
Well, if you are having distributor issues, that would effect timing and in turn would effect boost and you WILL run the risk of blowing your motor once in boost. You won't be able to tune your engine correctly at all.
FIX YOUR ECU CODES FIRST. Remember to reset the ECU each time you make changes. I usually unplug the ECU to make sure everything is reset and then plug it back in, because sometimes pulling the hazard fuse on some cars doesn't do it.
Old Dec 20, 2005 | 11:29 AM
zxc4's Avatar
ok thanks man
punkracer
12
Nov 2, 2006 04:09 PM
VTECth1s
Aug 9, 2006 10:10 PM
loid
Oct 9, 2005 01:43 PM
iwhichisme
Apr 1, 2004 05:41 AM
CiViC SiR
Jul 27, 2003 04:38 PM
